Main Menu
RealDash
Started by 1979scotte, April 30, 2019, 12:10
Anybody using realdash?
I've just found out it's compatible with loads of after market ECUs as well as various other devices and for a few quid it seems a very powerful tool.
Certainly better than the Ecumaster apps one of which won't run for more than 20 seconds and the other that thinks I'm running 3psi of boost at idle.
Yup, I used the full version with the EMB. Beautiful piece of software. And it has specific support for the ECUMaster using the EDL module, which you should have anyway
Quote from: shnazzle on April 30, 2019, 13:46
EDL?
Mine is a classic and I have a Bluetooth dongle.
I'm very impressed with realdash.
Have bought a really good dash for it. Not pretty but displays all the important info in easy to read format.
The standard dash is pretty enough for me.
Quote from: 1979scotte on April 30, 2019, 15:18
EDL?
EDL-1 is the Bluetooth datalogger. But if you have the Bluetooth module, same difference only without the SD card and log writing. I did find the application very finecky to modify a dash. Maybe easier on a big tablet and then copy to phone
