apexi intake query???
Started by Anonymous, March 29, 2005, 20:05
i have got an apexi winging its way to me and was just wondering if anybody has modified the standard air box to house the apexi cone filter????
i am not to keen on mounting it where it should mount and i want to try and keep the inlet pipe on the bottom of the airbox to try and aid in the air flow towards to filter.
any thoughts on whether this would be a good or bad idea????
I have to ask why bother?
you might as well just get a good panel filter if your goingto do this.
thats true but you dont get the sound increase with a panel filter, or do you????
Quote from: "jonboy"thats true but you dont get the sound increase with a panel filter, or do you????
I noticed a difference with the TRD one; but not too the extent of an apexi suck  s:wink: :wink: s:wink:
Just fit the bloody thing and enjoy it!  s:roll: :roll: s:roll:
but then if you stick a big lug of plastic allr ound it and seal it in. you probably won't hear it either  :-) :-) :-)
thats very true.  s:D :D s:D
you have answered my question as to whether to do what i was gonna do.
if it aint broke dont fix it as the saying goes.  s:lol: :lol: s:lol:
How about a half-way house solution? I fitted the Apexi as it should be fitted but then I modified* the air pipe that used to run into the air box so that it now points directly into the Apexi and (hopefully) blows cooler air in its general direction.
Can't say how good or bad the idea is as I've never made a comparison but I thought it was a good idea!
*For modified read: 'cut in half and attached some aluminium flexi-pipe'    s:D :D s:D
Jap GT300
If you open up an S2000 air box guess what you see?  A cone filter!
If you were going to mount your filter like this then I would also drill holes in the bottom of the airbox to aid the cold air feed and that essential noise.
jono that is eactly what i want to achieve.
i wish to keep the same air flow that goes into the stock air box, and hopefully being still able to use the inlet pipe i brought.
have you any pics that i can have a look at please.  s:D :D s:D
thanks for the other advise about drilling the holes in the stock box but im not sure if the apexi cone will fit into it. i will have a look once the kit arrives.
Quote from: "Jono & Emma"How about a half-way house solution? I fitted the Apexi as it should be fitted but then I modified* the air pipe that used to run into the air box so that it now points directly into the Apexi and (hopefully) blows cooler air in its general direction.
I don't think anything is going to "blow" through the airbox feed pipe; it runs back into the engine bay (behind the battery) and so there's no positive pressure to 'blow' into it.
Attach an engine to it of course (via the entire (sealed) intake system), and you will get air being 'sucked' through the pipe however).
Hey, like I said, don't know if I achieved anything but was worth a try!   s:D :D s:D
what does the pipe do that comes off the stock air box and heads towards the rear light do then???? on the bottom of the air box????
Quote from: "jonboy"what does the pipe do that comes off the stock air box and heads towards the rear light do then???? on the bottom of the air box????
That's the one that does a nice 270degree turn and heads back up toward the battery..
I know.. Odd  s:) :) s:)
