how to install Power Up window
Started by james wilkinson, June 7, 2019, 16:18
james wilkinson
hi  has anybody got diagram for information ,  how to install    Power   Up  window  thank you James
How do you mean install it?
Or are you just after schematics for the electrics?
If so, register (for free) on Toyota's own technical site.
https://www.toyota-tech.eu/Registration.aspx
Once you're registered, you can purchase access for as long as you need to ALL of the technical schematics.
https://www.toyota-tech.eu/OnlineSubscriptions.aspx
3 quid gets you an hour of all you can eat content. Which is downloadable... How long you can keep it for. Is dodgy territory but interpret that as you want.
Link to wiring diagrams is, after you've bought a subscription:
https://www.toyota-tech.eu/euro5search/index?PUBTYPE=EWD
You just need to pick the car
As I remember there is no easy win to do this. The auto function on the drivers is controlled by the body controller. It's not just a case of installing a switch.
Quote from: StuC on June  7, 2019, 17:05
This is true. Its because it links in with the immobiliser/key fob
That's another difference with the MR S!  Didn't know about this one.   My body controller fuse is out - no beepers.  BUT the auto window function still works.
james wilkinson
hi thank you for your help I've got the power up kit , I heard that  wire   goes to the passenger   switch in  centre console ,   and  wire  goes to the driver's door window , just wondered anybody had pictures of knowledge
