hardtop adds rigidity.
Started by 105e, August 25, 2019, 18:22
105e
33 degrees here today so removed hardtop to go for a drive. Much more scuttle shake with it removed, it definitely adds some rigidity to the chassis i think.
Quote from: 105e on August 25, 2019, 18:2233 degrees here today so removed hardtop to go for a drive. Much more scuttle shake with it removed, it definitely adds some rigidity to the chassis i think.
Yes, you're right about that.
With Dev´s door spacers, the difference is minimal.
The hardtop is sort o a brace fitted to the top of the windscreen where the movement in the tub is largest, but it is not a rigid fitting.
The door spacers are way lower but also a more rigid connection stiffening the tub.
Apart from the difference in steering response the reduced effect of fitting the hard top was for me proof of the door bushings.
