Transmission Fault Light
Started by Anonymous, April 7, 2005, 08:57
Hi there, very technically inept so stay with me. My mr2 is 3 and a half years old, 24000 miles. The transmission fault light came on yesterday, so electrical, no problem accelerating. Toyota reckon it could be a sensor, anyone out there had a similar problem? If so, what was the cost?
GSB
I take it you have SMT?
Jap GT300
In the SMT that light also warns of low clutch level, although you haven't done many miles.
Did toyota tell you what code it was?
My car is a normal manual, the text in the Mr2 manual  next to the fault light symbol mentions potential problems accelerating, which I don't have, SMT issues, nope, or general engine electrical fault. This morning when I spoke to them they mentioned that it may be a 'sensor' issue. I don't have a clue what sensors are in there!
GSB
So you mean the "Check Engine Light"? Get the car to a dealer who can read the diagnostic codes off of the computer. Once you have the code, you can decode it here, and find your solution. Until then all you have is a light on, which could mean hundreds of things.
Quote from: "GSB"So you mean the "Check Engine Light"? Get the car to a dealer who can read the diagnostic codes off of the computer. Once you have the code, you can decode it here, and find your solution. Until then all you have is a light on, which could mean hundreds of things.
Or lets take a wild guess. You recently filled her up and didn't tighten the plastic fuel cap all the way? Probably the #1 cause of "useless" warning lights  s:? :? s:?
If it was that, you can clear the code by removing the battery for 5-30 mins. If it comes again after tightening the cap, then it's something more serious.
GSB
Quote from: "Tem"
Never done that one myself, so I probabley wouldn't even have considered it! I am however an expert on fixing ye olde "passenger window failure" problem...  s:wink: :wink: s:wink:
Quote from: "GSB"Never done that one myself, so I probabley wouldn't even have considered it!
Me neither, just something I've noticed on SC  s8) 8) s8)
QuoteI am however an expert on fixing ye olde "passenger window failure" problem...  s:wink: :wink: s:wink:
So you had that too?  s:lol: :lol: s:lol:
I know *KRMH*someone*KRHM* who was already checking fuses and wires cause the bloody passenger window wouldn't go down  s:oops: :oops: s:oops:
Quote from: "Tem"I know *KRMH*someone*KRHM* who was already checking fuses and wires cause the bloody passenger window wouldn't go down  s:oops: :oops: s:oops:
  s:shock: :shock: s:shock:  DOH!  s:shock: :shock: s:shock:
So guys, Toyota are saying that it is a faulty exhaust emission sensor (1 of 6), checking which one now. They are quoting approximately £160 all in. Does this seem reasonable?
Jap GT300
They are referring to an O2 sensor.  You can buy them yourself cheaper and it's easy to swap.  If you ask them for the codes that are being read out then we can confirm this for you.
Quote from: "forza hibs"exhaust emission sensor (1 of 6)
They said you have six emission sensors?  s:shock: :shock: s:shock:
AFAIK, all EU models have only three sensors in the exhaust. Two are before precats and only monitor the mixture, one is after the main cat and that's the only sensor that's sniffing for emissions.
Now I could understand if they said 3, but 6?
Quote from: "Tem"
not got 2 banks in one sensor have they?
Quote from: "kanujunkie"not got 2 banks in one sensor have they?
I'm pretty sure one sensor is just one sensor. 4 wires, 2 for heating and 2 for measuring (signal+ground).
Of course the ecu thinks of one of the two sensors for two cylinders, but I can't see how that would make them talk about 6 sensors  s:? :? s:?
nope, totally agree if its 4 wires, me thinks they speak sh1t
They are now saying that it will be £220 including VAT, can I ask for a 'Diagnostics' print out (showing the problem) to confirm that I am not being fleeced here.
Quote from: "forza hibs"They are now saying that it will be £220 including VAT,
HOW MUCH?!   s:shock: :shock: s:shock:
Generic 4 wire sensors are about £50 (although you have to do a little rewiring of the broken sensor), and I'm sure others have said they fit... guys?
See here:
http://www.gendandirect.co.uk/viewproduct.php?product=O24WIRE
