Pre cat removal - Instruction manual
Started by Anonymous, April 7, 2005, 22:31
Good day all
This weekend i have the dreaded task of pre-cat removal on a 2001 MR2 Roadster, I am an ex-mecanic and currently work as a technical consultant for FPUK suppliers of Cats and EMS.
Just wondering wether i should take my time and take step by step
pictures and make an instruction book for the removal of these not necessary engine killer pre-cats??? Im sure yes would be the answer
so check my post next week for a full run down.
For the record if you own a Roadster you may not wish to know although it is VERY important that you do,  the pre-cats go off like a time bomb it starts at approximately 30 - 35k miles, the first sign sounds like a loose bolt on the manifold heat sheild which gets louder and louder till suddenly a few days later you start your car and the loud rattles and rasps begin, in week one these happens only when cold or till the monolith expands but get progresivley worse till unbearable. What im saying is if yours are ok at the moment print off my next post of instrutions because this job awaits you!!! Yuk!!
PS sorry for poor english / spelling but Budwieser has affected me!
Hi, and welcome!
One of our members has already done a comprehensive write-up on pre-cat removal, so it's probably not worth your while stopping to take pictures as well: on the other hand, it might be nice to see how someone else does it.
One other point: There is no definate time frame for pre-cat destruction. Most people's never go, and some (including myself at 16K) have had there's go a lot quicker than the 30-35K you say.
Bloody hell you must thrash yer car then?  16k!!!!!
I picked up the info from some tech boff abroad but that was a while ago when there wernt so many Roadsters in UK, my car has done 27k and boy is it rattling... sounds like a clapped out Fiesta at the mo... i wont be having the top down till its done, infact i may just wair a bag on my head till i have!   s:oops: :oops: s:oops:
It's nothing to do with thrashing the car: after I found out about my RH pre-cat, I went straight to Mr T and had the whole manifold changed. Three days later I removed the (brand new!) pre-cats, and the LH one already had a crack in it.
If your pre-cats have already gone (loss of power and huge oil consumption too?), then getting rid of them is the least of your problems. Have you got any sort of extended warranty?
All i have at the mo is a loud rattle, if anything the car is flying just lately, oil consumption is fine (not moved on level rod since last service in Oct 04) , no coolant loss either.
Warranty run out last July.    s:cry: :cry: s:cry:    s:cry: :cry: s:cry:
Bongo
Main cat heat shield maybe?
Mine's developed a bad rattle recently and i'm 100% sure it's not the pre cats  s;) ;) s;)
Quote from: "LLOYD"Good day all
pictures and make an instruction book for the removal of these not necessary engine killer pre-cats??? I'm sure yes would be the answer
For the record if you own a Roadster you may not wish to know although it is VERY important that you do,  the pre-cats go off like a time bomb it starts at approximately 30 - 35k miles, the first sign sounds like a loose bolt on the manifold heat sheild which gets louder and louder till suddenly a few days later you start your car and the loud rattles and rasps begin, in week one these happens only when cold or till the monolith expands but get progresivley worse till unbearable. What I'm saying is if yours are ok at the moment print off my next post of instrutions because this job awaits you!!! Yuk!!
not to be sarcastic but if you'd searched you'd see that as a community we are well aware of teh issue, and it's been covered ad nauseum.
however good luck  :-) :-) :-)
Looked and horrified... my god I purchased an MR2 for its Boxter looks, Value, Economy and reliability... i think im going off them now, quite a lot of negative posts  s:cry: :cry: s:cry:
I think i shall take of my heat shield first and try it then but the thing that makes me think cat is the fact the rattle goes when hot???
That is usually the first sign of cat failure.
Liz
To save you some trouble Lloyd so that you can get on with the job in hand - the first post in this link is Grants comprehensive guide to de-catting, as Mark said we are all very aware of the problems with the pre-cats and more and more of us are taking them out. Have fun with yours!
 m http://www.mr2roc.org/phpBB2/viewtopic. ... 07&start=0 m
GSB
The ratting that disapears when the car is hot is a heatshield failure. Nothing that 10 minutes with an angle griner wont fix.
Search for " heatshield and rattle " and you come up with this: Whilst I admit its not a technical post as such, it will show you the way to stop embarrasing yourself at the traffic lights...
Quote from: "GSB"How come no-ones mentioned the bloody heat shields yet?
I'd put money down that your problem can be cured in 10 minutes with GSB and his faithful angle grinder... Crawl under the car, and just below the point where the manifold connects to the main cat, begins a series of heatshields that extend all the way over the body of the main cat, towards the silencer.
Most of these metal pieces bolt on, and are secured by metal bands. But the one right at the front where the 2 downpipes joint together is made of 2 half shells that bolt together, with one side being welded with 2 small welds to the pipes themselves. These tiny welds crack, and when the exhaust gets hot enough, it starts to vibrate...
Now, the only way to get it off, is to remove 2 small bolts that secure the rear of the 2 shells to the adjacent shield, and the grind out the bolt that goes through the middle of the 2 downpipes. You could try undoing it, but it's be a futile excersize as Toyota weld them in once they're done up...
I diagnosed mine with a long screwdriver. I got the engine nice and warm, as it was silent until it got hot, and then had a friend hold the throttle at a point where I could hear the noise. Then by prodding around with my long screwdriver under the bonnet, I touched it upon the heatshield and the sound vanished...  10 minutes of grinder action and the heatshield was history, although I could have just claimed for a complete new cat under warranty...
Hi Lloyd,
I'm fairly sure it's going to be the heatshield, it sounds exactly as you've described.  Although getting those precats out isn't a bad idea generally.
Quote from: "LLOYD"I am an ex-mecanic and currently work as a technical consultant for FPUK suppliers of Cats and EMS.
Small world.  Is Paul Tomlinson still there?  Say Hi for me  s;) ;) s;)
Lloyd,
please remember that this is a forum and as such is going to highlight in neon lights any problems that occur on the 2's, but what it doesn't do is highlight all of us who havn't had any problems at all, i myself have had nearly 30K trouble free miles and yes i do thrash the hell out of it!
here here!
Thanks all i can see now (as i said im new to the site) that the pre cat story has been over done.
I will remove my heatshield in the morning and see if the rattle disappears.
Thankyou for the info
Just started stripping down MR2, took under cover off and found that the lowest heatshield on the exhaust has broken free, they are welded but my weld has broke, slight bend with the screw driver and now its mint! Phew... i can go for a cruize now as apposed to gutting those pesky cats!
Thanks all for all of the advice on saying it was heatshields... you are the boys!
If you were going to do it anyway, I'd still recommend getting rid of the pre-cats anyway, even if just as a precaution. At the least, it's probably worth having a peek under the O2 sensors to see what condition our favourite honeycomb-alike-stuff is in.
Looked through the Lambda holes, pre cats look mint, no cracks at all, although i will be taking your advice, im just waiting for a warmer day, its freezing today! Brrrr
