How much heat-wrap do I need?
Started by househead, October 7, 2019, 13:04
BahnStormer
All done... revs out v nicely, deeper burble and definitely makes a few more pops and bangs on the over-run!
BahnStormer
Ended up asking Pat (Headcase) to do it - mostly 'cos there was no way I was going to get a flat space to jack it up for MONTHS... but the top bolts were crumbling anyway, so I couldn't even get the PlusGas in there... Pat had to cut the heatshield off...
Happy for you that it makes you smile.
Sure looks a sorry pile, the old set up.
Can´t say I like the wrap look but hey, no discussing taste; some like the mother, some the daughter and I usually both, just not thís time ;-)
Have fun!!
BahnStormer
Quote from: Petrus on May 14, 2020, 19:10Can´t say I like the wrap look
I thought the wrap was pretty much mandatory... I was very tempted by a nice orange ceramic coating, but I think the cost was going to be more than the manifold + install cost together! Please correct me if I'm wrong on that.
Quote from: BahnStormer on May 15, 2020, 07:29
Definitely not mandatory.
It helps.
As for ceramic, I'd definitely not "waste" it on a ToyoSport and to be fair, as good as it is, it's not necessary. It's for thr track folk or people with deep wallets :)
Quote from: shnazzle on May 15, 2020, 07:36It helps.
Like with any good myth, there is a grain of truth but the question is it helps whát? and even then the jury is out on it.
Quote from: Petrus on May 15, 2020, 08:57
Nah, there's no jury needed. Hot gasses flow faster. Period.
Wrapping keeps heat in the manifold, increasing temp.
But it's been covered enough so no point opening that topic again. Even I'm sick of it
Quote from: shnazzle on May 15, 2020, 09:03Nah, there's no jury needed. Hot gasses flow faster. Period.
As I wrote, there is a grain of truth in every good myth.
However you rule so...
...and I have not wrapped mine.
BahnStormer
I wasn't sure, but I just thought if I was deleting the heatshield, then I needed something to stop too much heat building up in that part of the engine bay...
At very least this way, it heats up the cat faster and moves the heat to somewhere with better airflow to dissipate it out the engine bay... and presumably helps with pops and bangs... which EVERYBODY knows make your car go much faster...
It cost £12 and took <1hr... shiny silver looks better though, just a shame it won't stay that way...
Quote from: BahnStormer on May 15, 2020, 11:33I wasn't sure, but I just thought if I was deleting the heatshield, then I needed something to stop too much heat building up in that part of the engine bay...
Logical thought I totally agree with. I looked for a header with the brackets to refit the OEM heat shields to avoid having to do the same.
BahnStormer
Quote from: Petrus on May 15, 2020, 11:43I looked for a header with the brackets to refit the OEM heat shields to avoid having to do the same.
Decent idea, but mine looked like shrapnel afterwards... so I sould have been buying a new one... I'm happy with mine as it is right now, just hoping it lasts...
Quote from: BahnStormer on May 16, 2020, 19:02Decent idea, but mine looked like shrapnel afterwards... so I sould have been buying a new one... I'm happy with mine as it is right now, just hoping it lasts...
The ceramic stuff should last ok.
