Need some Goodyear F1's!- our size doesnt exist!
Started by Anonymous, April 8, 2005, 23:20
Looking to replace my rear tyres and have a 2000 model. I used Goodyear F1 last time and want to keep the same performamance level on all 4 tyres. Does anyone know where I can get a replacement set from. Seemingly they are out of production now so I will be looking for a backloged pair  s:( :( s:(
If not can anyone advise me where I can get a pair of Bridgestone S-02 Pole positions cheap (eg online).
Thanks guys!
  s:D :D s:D
tyresave may be worth a try, were quoting F1 during the week but didn't actually state they had them in stock
Tried, not our size  s:( :( s:(
205/50 R15's needed in F1 form.
QuoteIf not can anyone advise me where I can get a pair of Bridgestone S-02 Pole positions cheap (eg online).
Retail S-02 long gone I thought, replaced by the S-03's by Bridgestone. There are OEM versions of the S-02 for specific cars e.g. pre-04 S2000 and a Porsche of some sort but not sure I personally would use a tyre that had been designed for a particular car that wasn't mine.
If you end up having to ditch the F1, the Toyo T1-R seems to get positive reviews and comes in your size I think.
I think you are right - there doesnt appear to be a GSD3 in the right size - you may still have some luck trying to get GSD2s - i got one (in a different size) in the last few months...
Will 205/55R15's fit? they do these in GS02 F1's, how do they look compared to the 03's?
Went through all this last summer and couldnt get hold of the Goodyears from anywhere.  At the time, Goodyear advised that they would not be making the size we need (whether this is true now im not sure)
In the end i bought a pair of Toyo Proxes - very similar pattern and an excellent tyre in my opinion.  Running them at the rear with the F1's still upfront and all seems ok.
thanks!
i will look into some toyos!
S-03s rule!
Quote from: "Beanie"S-03s rule!
What he said!
Do you know of an onloine reteailer who sells them cheap? I just need them delivered not fitted.  s:) :) s:)   getting my wheels repowered!
Quote from: "mattmr2"In the end i bought a pair of Toyo Proxes - very similar pattern and an excellent tyre in my opinion.  Running them at the rear with the F1's still upfront and all seems ok.
Erm.. I did that (GSD-2s front, T1-Rs rear).  It's not a good combination in greasy conditions   s:scared: :scared: s:scared:
well that will make things interesting at least. mixing any tryres isnt ideal but what can you do? im not going to spend another £135 on tyres i dont need.
What kind of behaviour did you get? Oversteer or understeer? or what?
Bongo
£135 sounds expensive for 2 proxes, have you tried camskill?
Although if they're dangerous maybe that's not a good idea.
Personally I'd just change all 4 and be happy that I have decent, matched tyres.
Quote from: "vibratingsky"What kind of behaviour did you get? Oversteer or understeer? or what?
In the dry, mild understeer and a floaty feeling at speed (compared to GSD2s all 'round), but that changed to snap oversteer when slippery (and not paying attention to changing conditions   s:roll: :roll: s:roll:  ).   Even worn Yokos were more easily "catchable".
After one little *ahem* incident I would never mix tyres on the '2 again. £135 is (probably) less than your insurance excess...
Too right, my Golf GTI got a bit lairy in the greasy conditions a few months ago because one rear was Dunlop, the rest were Michelins. Managed to get some serious sideways action a few times before I took the car to Kwikfit and got them to get authorisation from the lease company to change the tyre even though it still had a few thousand miles left on it.  It shit me up even though I had the safety net of ESP.
£135 is not a lot to pay if it stops you "backing in" next time you push it round a bend.
Yeh I bought them a set of 4 for £200. Not bad really.
Least i will be able to thrash her again at the track  s:wink: :wink: s:wink:
I'm running 195/50-15 front and 225/45-16 rear in the S-03s.  The rears are Z-rated.  Only had them on for a day, but wow, what a difference.  No hint of breaking loose at 9.G.  They may hold on good warm surface up around 1G (on my car anyway).  The rears are a little larger outside diameter (definitely) and the fronts are a little smaller (I think) than stock 2003 tires.  No rubbing, despite H&R lowering springs and 3mm spacers all around.
Correction: front and rear are Z-rated.
