Valve timing question
Started by Petrus, November 11, 2019, 15:34
Appearantly it makes hardly any diffence to drop a set of sports (CAT)cams in the 1ZZ.
I don´t doubt this because it is experience based.
It does not stop me wonder whý.
Comparing the standard and Cat-cam timing there should be more a difference then there is.
Any thoughts here?
Nvy
Quote from: Petrus on November 11, 2019, 15:34Appearantly it makes hardly any diffence to drop a set of sports (CAT)cams in the 1ZZ.
Any thoughts here?
Based on my reading its due to many things combined but mainly head design, valve area, narrow intake(read TB and manifold) and header/exhaust design. Basically it lacks in everything compared to k series/2zz.
You can drop a set of stage one cams in and see some benefits with the standard ECU.
Add in some basic changes to the intake and exhaust and a piggyback/standalone and SOME have dynoed up to 170bhp.
But it's a massive money pit to look for 15-20 hp gains.
Stage 2 will improve the mid range torque but not necessarily top end.
You're kissing goodbye to at least £3k though to do it right.
Quote from: Call the midlife! on November 11, 2019, 18:48You can drop a set of stage one cams in and see some benefits with the standard ECU.
Accurate summing up of what I´d read.
All is all it seems that the design of the head; porting/combustion chamber is what sets the power graph and the rest is a rather well matched design within the parameters of environmental requirements.
Fits with Toyota going to Yamaha for a performance head and again design the perfect chain of flow = 2ZZ.
Makes sense. Still takes some to get my head accustomed to decénnia of classic tuning (for speed) around it.
