post pre-cat removal and oil consumption
Started by Anonymous, April 9, 2005, 15:40
Since having my pre-cats gutted around 3 months ago as one of them broke up, my car has suddelnly started using more oil. It now needs topping up every other week.
The car is due for a 30k service so could it be due to dirty oil as to why its using more?
Also i am topping up with semi synth 10w40 and wasnt sure that was the grade of oil in there before.
So, will my engine continue to carry on as it is, i.e. still pulling as strong as ever but with increased oil consumption or will it eventually die?
main cat was replaced also, and car has done over a 1000 miles since de-cat
thanks in advance for any replies
darrenjuggins
Hi,
Unfortunatly, sounds like you have an engine wear problem, mine was the same after the cat was replaced, ran fine, but drank about 1tlr of oil to 250 miles, still ran exactly the same as always, i guess the cars brain, sorts it all out, but you still have the same issue.... large oil consumption, whici will eventually kill your Cat due to the excessive oil being deposited from the engine.
If you are still within warranty or have extended warranty, then they will investigate and you should get a new short block and all relevant parts, if not in warranty - have a word with Jap300 about a replacement block.
Hope this helps, it's not nice but I'd rather not flavour it up.
Darren J
Darren A. Juggins
exactly same thing is happening with me since having my new main cat fitted, done a 1000 miles since having it back, and it's consumed nearly 4 litres of oil, luckily still under warranty, so it's going in this week
'short block' meaning cyliner head? is this a big job to replace as funds are on the low side at the mo.
pretty much.
you may be able to band aid it by using heavier weight oil for a while, if funds are tight though it won't last forever
GSB
"Short block"
The main body of the engine, minus all ancilliaries, and minus the cylinder head. Essentially you get the crankcase, sump, crank, rods & pistons, add your own head, flywheel, water pump, and depending upon the manufacturers design, the oil pump.
A "long block" also includes the cylinder head.
