02 sensor blank check engine
Started by Stag, December 1, 2019, 13:27
Stag
I'm back with another problem, hope all are well.
I've decided I'm moving to New Zealand in February. Leaving everything behind and going for it. So I need to get the mr2 ready for sale.
I have a problem where if I drive more than 10 miles or rag it a little bit I get a check engine for all the 02 sensors giving a blank response. I've tried putting in different sensors but still the same problem.
I've got a full after market exhaust with no cat, but I didn't have this problem before we swapped the new engine in. It can be cleared instantly. Any ideas ?
Well- it's normal to get the check engine light with no cat.
So in this instance it's behaving correctly.
However no codes is weird. Have you tried a different code reader? Preferably a wired one..
H1GRM
Quote from: jvanzyl on December  1, 2019, 13:51Well- it's normal to get the check engine light with no cat.
Don't get check light with the GG and no cat.
https://www.mr2roc.org/forum/index.php?topic=66294.0<br /><br />TTE Turbo 6R4 Forest Green - Y55 GRM <br />Jeep Wrangler - H1 GRM
