getting to my front suspension mounts
Started by Anonymous, April 11, 2005, 13:13
Hi all
Can anyone tell me how to take the plastic covering off to get to my front suspension mounts.
I thought it was just held in by those popping clips but after trying to remove one it just snapped and i didnt want to try anymore.
cheers
Alan
push in teh centre of teh pin
it will click in, and the whole pin can then be pulled out
If you plan on having the plastics on and off a few times, visit your dealer and pick up a dozen extra clips. They tend to break.
cheers
They shouldn't break, if handled properly. Press the centre in gently and lift from the edges. To put them back, lift the centre up, put the pin in and press the center level.
I've had mine on and off several times and never broke one. You don't need to apply any force at any point, so if you do, you know where you're going wrong  s8) 8) s8)
Quote from: "Tem"They shouldn't break, if handled properly. Press the centre in gently and lift from the edges. To put them back, lift the centre up, put the pin in and press the center level.
You must be lucky Tem  s:shock: :shock: s:shock:  I have had the plastics out a few times and sometimes as you push down on the centre pin it breaks one of the four legs off  s:? :? s:?   Funny enough I have just ordered half a dozen from my dealer. And they charge 54p each  s:shock: :shock: s:shock:    s:shock: :shock: s:shock:    s:shock: :shock: s:shock:
those same pins are 10cents each in teh US
54p each!!! Take a sample to to either a factor or a Vauxhall dealer, they are know as expanding rivets Vauxhalls are virtually held together by these, ie under wing guard rivets on a 96 Corsa are the same but made of better plastic and cost 8p each!!!
  s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)    s:) :) s:)
Quote from: "LLOYD"54p each!!! Take a sample to to either a factor or a Vauxhall dealer, they are know as expanding rivets Vauxhalls are virtually held together by these, ie under wing guard rivets on a 96 Corsa are the same but made of better plastic and cost 8p each!!!
I had a heartattack when they told me too  s:? :? s:?
Toyota.... we ar watchin you and yer telephone number pricing!   s:evil: :evil: s:evil:
Quote from: "heathstimpson"You must be lucky Tem  s:shock: :shock: s:shock:
Can't be luck as I've removed and installed those pins a few hundred times  s:lol: :lol: s:lol:
(counting pins, not the surround removal times)
you boys must learn not to thrust it in too hard or you'll always end up brakeing something   s:wink: :wink: s:wink:
Quotethose same pins are 10cents each in the US
Not in my U.S.
Dealer charges me $1.25 each. I just gave him a look, and said, "These things break too easily." He reduces the price to $1. Tem might be lucky, but what I've noticed is that not all of the holes mate perfectly with the poppets. The ones mounted slightly off-centre put extra stress on a few of the poppet legs and "bam!" you snap off one or two of them. That's just life. Last time I was at the dealer - and I'm pretty chummy with these guys - I noticed the mech has a huge supply of poppets in all varieties, grommets, vacuum caps, these things are expendable and regular service requires their periodic replacement.
Quote from: "southerneditor"Tem might be lucky, but what I've noticed is that not all of the holes mate perfectly with the poppets. The ones mounted slightly off-centre put extra stress on a few of the poppet legs and "bam!" you snap off one or two of them.
You're right, they don't line up. I always try to move the plastic a bit, so each one would line up as close as possible. They don't seem to break when they are on the hole, even if there's some stress on them. The plastic legs are tiny, so you don't need much force to break them. That's why I don't use any force  s;) ;) s;)
Toyota has been using those same clips since the 80's and I've had several cars with them. I don't believe I'm on a 10 years lucky streak, must be something else  s:lol: :lol: s:lol:
Not in my U.S.
hmmk, I bought a shitload from Carson Toyotya a couple of years ago and I'm sure they were circa 10cents
Quote from: "Tem"
You must just have too much time on your hands Tem where you can take that extra bit of care  s:wink: :wink: s:wink:  On the other hand I am always trying to beat the clock in the evening as the sun sets   s:? :? s:?
Quote from: "heathstimpson"You must just have too much time on your hands Tem where you can take that extra bit of care  s:wink: :wink: s:wink:  On the other hand I am always trying to beat the clock in the evening as the sun sets   s:? :? s:?
I've learnt that it's better to take your time and not break anything, cause it'll be faster in the long run  s:? :? s:?  Of course a plastic pin isn't as big deal as a snapped bolt or killed thread, but anyway...
2x500W halogens are a nice substitue for the sun, if you run out of time  s;) ;) s;)
