Trouble starting car
Started by Anonymous, April 11, 2005, 22:12
Hy.
Couple of days ago, my car didn't start. When i turned the key it just made some strange noises. I don't know, how to describe it - like normal starting, but 50% slower and very louder. Very scarry and painful experience. I was realy scared that something is wrong with the engine. Then after i tried to run it couple of times (in desperation)  it just started. It's been days now and car works perfect. Any ideas?
how's the weather been?
driven much recently?
possibly just got some damp spark plugs, but to be honest, more info needed to make any form of decision
Flat battery?
Jap GT300
Quote from: "mrbarney"Flat battery?
Is it an SMT?  If so this is your cause.  When they have around 11v in the battery the car will atempt to start and turn it's self off over and over, sometimes it may actually catch and run.  It doesn't do any harm.
If it's a manual, the car will click fast (starter motor relay) and just wont start
Quotehow's the weather been?
The weather was sunny and fine and i've been driving a lot lately (15000km from January)
QuoteIs it an SMT? If so this is your cause. When they have around 11v in the battery the car will atempt to start and turn it's self off over and over, sometimes it may actually catch and run. It doesn't do any harm.
It is SMT. So you think it is a battery thing and  nothing serious? Happend to you before?
Any ideas what to do if it repeats?
Thanks.
IIRC (I don't have an SMT myself) when you open the drivers door, the SMT clutch actuator pressurises (?) so that the clutch is disengaged and you can start the car.  If the battery is flat, this isn't going to happen, or at least it's going to struggle.
Low charge in the battery would also mean the electronics would get upset when cranking as the voltage drops further,  and the cranking speed would be slower anyway.
What to do - well, if this is the case, try the usual things with flat batteries.  Take it off and charge it, ideally, but you *could* try jumping it (disclaimer - reported that it can cause damage to electronics when connecting / disconnecting donor car, never had a problem myself.  Do it at your own risk).
Alternatively, take the battery off and get it tested next time it happens, assuming you have other transport.
