Putting the top down from inside the car
Started by Anonymous, April 12, 2005, 09:23
Ive previously read that people can put the top down from inside the car, and well, I just can't. Firstly the window needs squashing down, and then to make it click into place i need to whack it down with force that is not possible from inside the car. Either you guys are weight lifting grippers, I am weak, or there is a technique. Please help. ta
SimonC_Here
A lot depends on the roof and the temperature.
I tend to get out to put the roof down to avoid damaging the glass. However in the very sunny days, the roof has fallen all the way down and clicked shut on its own after just opening the clips and pushing it back a little.    s8) 8) s8)
Saves getting out of the car but it does worry me sometimes.
Simon
It doesn't often work for me either.  Only ever works when it's really warm and the cars been parked in the sun for a while.  Normally takes two attempts too.
Nope, only ever been ble to do it once and that was in a traffic jam, on the motorway, blazing sun and needed to get roof off. Been in sun for about an hour, so was REALLY warm and it went down a treat. Other than that, its definately an outside, press and slam job.........
NEVER put the roof down from the inside.....
If you do even on a hot day you will see the two rear corners of the roof stick out, if they dont split the roof straight away it could potentially tear whilst driving   s:cry: :cry: s:cry:
Its better to be safe than sorry so take five, put it down properley, push the glass down gentley and tuck in all the bits at the rear.   s:D :D s:D
Darth Paul
From inside the car all the time – unless it's very cold. When it's not too warm it takes a couple of attempts, but in the sun it 'slam dunks' first time, every time. Especially enjoy doing it when having to slow down, then it's do-able at speeds up to 30mph!  s:lol: :lol: s:lol:
Quote from: "Darth Paul"From inside the car all the time – unless it's very cold. When it's not too warm it takes a couple of attempts, but in the sun it 'slam dunks' first time, every time.
What he said  s8) 8) s8)
QuoteEspecially enjoy doing it when having to slow down, then it's do-able at speeds up to 30mph!  s:lol: :lol: s:lol:
And traffic lights when the rain stops! Especially when there some more expensive car next to you whose electric roof takes forever  s:lol: :lol: s:lol:
My mate (with arms like Tyson) ripped one of the hockey sticks clean off from doing it from inside!!!
Quote from: "LLOYD"If you do even on a hot day you will see the two rear corners of the roof stick out,
Lloyd, you might want to look here:
 m http://www.mr2roc.org/phpBB2/viewtopic.php?t=6773 m
  s:wink: :wink: s:wink:
Same here - ever since we got the car, I usually put the top up and down from a sitting position inside the car.  It's a little more awkward now, with the style bars, but still no great feat of strength.  As others have said, the hotter it is, the easier it is to click it into place.
Mrbarney   - thanks for that interesting link.
As for everyone else i still think if you havent done the strap mods put it down from the outside!
karlus972
Pretty much the same like everyone. I get off the car to do it. I read a thread in which the guy said that he broke his rear windshield putting the top down from inside. Very warm and it went quick and.....bam 700€   s:? :? s:?
Next the ears are coming off and it's definitly ugly.... so worth taking 1mn getting off the car and doing it gently   s:wink: :wink: s:wink:
Madinina Style!!
SimonC_Here
Never done the strap mod on mine. It has always worked as it should do, tucking the 'ears' in its self.
Simon
Never been able to do it properly from the inside; others I've seen just fall into place where my hood has always been a bit stiffer  s:wink: :wink: s:wink:
Liz
Do mine from the the inside in the summer using the slam dunk technique and my ears go in ok as well.
Quote from: "Darth Paul"From inside the car all the time – unless it's very cold. When it's not too warm it takes a couple of attempts, but in the sun it 'slam dunks' first time, every time. Especially enjoy doing it when having to slow down, then it's do-able at speeds up to 30mph!  s:lol: :lol: s:lol:
Same here, only thing is it fires the front of the locking catch out into the car and it can be a bugger to find sometimes (must glue it one day)   s:D :D s:D
I think ill get out to do it. It would be a bit pants on the motorway, i dont think it would be too wise to stop on the hard shoulder and put it down. - unless you want to be on one of those police video shows. My best topless experience was the other night, id played squash for 1 hour and had lost at least double my body mass in sweat and it was cold outside, it was orgasmic im telling you.
Darth Paul
Quote from: "Slidey McSlideSlide (dave"My best topless experience was the other night, id played squash for 1 hour and had lost at least double my body mass in sweat and it was cold outside, it was orgasmic I'm telling you.
TMI.......  s:shock: :shock: s:shock:
mrsmr2
I always found engaging the clip that's the difficult bit and have always had to get out to push the roof down in to the clip - I certainly can't do it from the drivers seat.
Since removing the hardtop a few weeks ago, I definitely have to get out and put it down by hand as the window doesn't lie flat at the first attempt.  I have the partly raise the roof and try again.  I expect this will go in the heat of summer again, and the roof may be a bit stiff from not being used for the last 4 months.
Mine from inside always, had no probs at all, sometimes the clip needs a punch. Never any ears.
But after reading this think I should look to see what could possibly go wrong
I have a stiff one to! Girlfriend said it aint a problem!   s:lol: :lol: s:lol:
since i've treated mine with autoglym bumper care stuff, mine drops straight into place from sitting on nice warm days, colder weather and it's a pig. glad this thread has come up, as it's nice too know my roof is pretty much the same everyone elses!
hmm
does Autoglym sting?  s:oops: :oops: s:oops:
Not all tops were created equal. On this side of the pond, we have a new owner who reports a top so stiff it requires two people standing on the sills to latch it closed.
Some owners have the dreaded "ears" right off the showroom floor and need Argioppe's "Unsnaggable Top Strap Kit" straightaway. Others have tops that function as promised.
I'm fully with Lloyd here - opening the top and stowing it back can be done on most cars in hot weather with a fully warmed top, but even so, it's a Bad Idea. You risk damage to the rear glass, the heating unit, the parts of the fabric that rub against the metal spars, and most of all, the retaining "pull" clip. After 3 years of ownership, my top looks new, it still "snaps" when pulling closed, and works perfectly. I attribute this to my policy of being gentle with it.
To keep things in perspective, whenever I start to think that maybe stepping outside the car a moment is becoming a burden, I just think back to the top on my '71 MGB, which was six sticks, a tarp and an instruction booklet. With speed and experience, you could get it on or off in about five minutes.
hey all
i can gently slide mine down. The glass goes down easily
the only problem i have is engaging the clip... so all i do is once its fully down i give it a good push, afterall the roofs down, you are only fighting against the clip of the latch.
