Good evening
Started by stuart, February 27, 2020, 21:44
stuart
Hi there. Now I know that what I'm about to ask has been covered in the past but to be honest reading the comments just leaves me more confused..it's about wheels...mine are coming up for a referb...and I know.. but keep reading.. I fancy these 17" D1R BPL ALLOY WHEELS...can anyone give me a definitive answer about offset tyre size etc ... sorry to have probably bored you all..but it's a lot of money to pay and find out they rub etc... totally standard 06 car
Regards Stuart
search for web site will they fit.
Good starting point.
17s are viewed by the majority on here as cosmetic only.
Some like how they drive, but not many.
I would suggest trying to find a ride in one before committing wine tokens.
Edit
Do you like how yours drives now?
Do you think it will be better on 17s?
stuart
Thanks for your comment..I like the drive on the standard wheels yes it's brilliant..I expect it's a cosmetic thing as I don't like the amount of tyre on the front compared with the rear wheels plus the front wheel itself doesn't seem to fill the arch enough.. nothing against the style of the wheels at all they are a good looking wheel and easy to clean and locally I can get them refurbished in a few nice colo0urs including shadow sliver for £188.. would a pair of rear standard wheels go on the front with wider tyres on the back and thinner on the front that would be great for me ..
Are you determined to spoil the handling of your car Stuart?  Because of the limited variety of tyres that are available 1n 15 & 16" that fit the car, some folk go up one size of tyre width on the front. They may then go up one width on the back, but not always.
I've seen mention of people trying wide fronts & not liking them. I believe guys that race them sometimes put the wider 15" rear from a pfl on the front of an FL, - maybe someone can confirm.
Bear in mind too the 16" rear wheel is quite a bit heavier than the 15" front...so changing that is slowing the car.   Ditto 17" wheels & 17" tyres... weight!
Wheel arch space... you could alter the springs or use spacers.  I have a set of spacers that I bought from a club member (ie off an MR2) but I have aftermarket wheels & nuts & can't use them.  PM me if you want info.
I do agree 17s look fantastic. The sp12 alloys we had are undeniably one of the best looks on the car.
We had
SP12 7.5j et45 + Uniroyal Rainsport 3s 205/40/17 weighs 15.5kg-ish (Front)
SP12 8j et50 + Uniroyal Rainsport 3s 245/40/17 weighs 18kg-ish (Rear)
And Matt did get them sized very well for the MR2.
I believe the tyre size on the rear was a bit oversized if I'm not mistake, should be 235, so we scraped a little on lowered tte springs. But on the intended setup that size never scrapes
We went back to 15/16 due to not liking the handling
Bernie
On a stock car 17" heavier wheels will effect the handling and performance
Mostly work better on cars with upgraded engines either turbo, 2ZZ etc
Note Pats comment above many end up going back to stock
SV-3
Quote from: Bernie on February 28, 2020, 08:10On a stock car 17" heavier wheels will effect the handling and performance
"Stock Cubed" 8)
Eclectic - not electric
Sony WX-920BT
"Hardtop Cognoscenti"
"Stock Cubed"
"AirCon Aficionado"
"Keeper of the Beeper"
stuart
Quote from: Gaz mr-s on February 28, 2020, 01:11Are you determined to spoil the handling of your car Stuart?  Because of the limited variety of tyres that are available 1n 15 & 16" that fit the car, some folk go up one size of tyre width on the front. They may then go up one width on the back, but not always.
sorry you start off having a dig then mentioned spring hight and spacers etc ..I'm sure that would alter the handling... anyway I don't like lowered cars dragging their arse along the road...then you say you have aftermarket wheels on yours ...I don't understand
Sorry you felt I was having a go, it was meant to be more light-hearted than that.
There's a big difference between slightly lowered & "dragging the arse along the ground".
A common mod is changing to Tein springs. The drop is approx 30mm. It does give the car a better stance.
But not a good idea unless the shocks are fresh.
Another option is to cut a little off the O/E springs. A few have done so.
Since you like the look of the std wheels why not keep them?  They are pretty light, - can't be said for many stock wheels.
I have aftermarket wheels, but in stock diameters. They need aftermarket nuts too, & the ones I use don't give enough thread to allow the spacers. They are ok with O/E wheels though.
stuart
Thanks for clarifying the situation..I wouldn't cut springs down to size not recommended at all .on the topic of different manufacturers wheels I have looked at that option however most manufacturers don't or won't supply staggered sizes as the originals...well not in my choices any way perhaps you would be kind enough to post a picture of your car ... thanks for your comments
stuart
I like these https://www.wheelbasealloys.com/alloy-wheels/rota/grid/gun-metal-polished-lip/16-inch/toyota/mr2/mk3-roadster
But can't find them in staggered sizes ... opinions welcome on these obviously with staggered tyre width
Or it's looking like a refurbishment of the originals.. expect that they have done well as would be first refurbishment
Bernie
Quote from: stuart on February 28, 2020, 15:48I like these https://www.wheelbasealloys.com/alloy-wheels/rota/grid/gun-metal-polished-lip/16-inch/toyota/mr2/mk3-roadster
Might be worth trying Demon Tweeks they supplied my previous Rota's in staggered sizes
SV-3
Quote from: stuart on February 28, 2020, 15:31Thanks for clarifying the situation..I wouldn't cut springs down to size not recommended at all .on the topic of different manufacturers wheels I have looked at that option however most manufacturers don't or won't supply staggered sizes as the originals...well not in my choices any way perhaps you would be kind enough to post a picture of your car ... thanks for your comments
Hi Stuart
Lowered c/w stock wheels...
Sony WX-920BT
"Stock Cubed"
"AirCon Aficionado"
stuart
Quote from: SV-3 on February 28, 2020, 16:05
Hi Stuart
That's really nice...iv found these with staggered tyre sizes..in 16" I'd appreciate your comments thanks
https://m.rimstyle.com/pages/basket/
stuart
Hi Stuart
Looking good!!
stuart
Quote from: Bernie on February 28, 2020, 16:04
Thanks for your reply and help in regards to the staggered sizes did you go for 16 rear and 15 front or 17 rear and 16 front?
Regards
stuart
Hi Stuart
Very nice looking car thanks for posting
I've been following this thread and biting my tongue a little. I do think it's generally agreed, that for everyday road use, the standard suspension and wheel set-up is as good as it gets.
As I pointed out to Shnazzle while we were working on his lowered car (he has BC adjustable struts) that you can't see the outside of the car while you're driving it!!
All of these cars are getting a little long in the tooth, and a refresh of the stock suspension works wonders.
To me these silly little cars are about driving fun more than anything, and I don't really care about 'looks'.
My vote is refurbish what you've got and spend the savings on new shocks and a-arms. ;D
Quote from: Carolyn on February 28, 2020, 18:51I've been following this thread and biting my tongue a
Spot on.
Very much like the soúnd of the exhaust: Who cares how it sounds to onlookers? It´s how it sounds while driving that matters! and with road holding it´s that to the power of it.
Now the caveat is that if you never drive the car like you stole it, 17" will be fine and yes, they do look more modern ;-)
Bernie
Demon Tweeks supplied 15" fronts 16" rears
Lowered on Tein MonoFlex Coilovers
stuart
Quote from: Carolyn on February 28, 2020, 18:51I've been following this thread and biting my tongue a little. I do think it's generally agreed, that for everyday road use, the standard suspension and wheel set-up is as good as it gets.
Yes well thanks for your odd comments..I don't really think of my car as being"silly" I quite like it that's why I kept it..I like the look of it and as it's only done 21000 miles from new and always always over serviced it's never used any oil/ coolant etc...used for summer runs only so I don't rate it as (long in the tooth)..and I don't intend lowering it as I can hardly get over the speed humps in our area now...yes I am probably just looking to asthetically improving the wheels only...but as I'm not Lewis Hamilton and never will be I'm fine with that thanks...if I want to get an adrenaline rush I go out on my Kawasaki z1000..but I appreciate you unclamping your tounge
Regards
stuart
Quote from: Petrus on February 28, 2020, 19:35
Spot on.
Thanks for your help
stuart
Stuart, apart from anything there is an objective criterium; the weight of the wheel.
Befóre you decide on anything, try to find out the weight of a 17" set with the possible wider tyres you would like.
Compare that with the OEM set and draw your own! conclusion, whether that is an issue for yoú. I spent a ´silly´ amount on líghter wheels ;-) but then I also cut down the OEM springs a bit and have a silly big wing mounted :-) oh and a tsurikawa :-O
If you decide on 17" or 16 and 17, and Rota would happen to have a style you like, then the brand is a value for money choice.
stuart
Thanks for your constructive reply . I actually had a set of lenso d1r 17 inch rims which were light weight but sold them because I couldn't make up my mind and didn't want to go to the expense of putting tyres on ..it's probably going to be the rota grid 16"all round with different tyre widths...or just the original ones refurbished..
Regards
