Hardtop blanking plate bolt size
Started by Ozzy, March 11, 2020, 19:47
Ozzy
Anyone know what sized bolts I need for the hardtop blanking plates?
They were never bolted down on mine since owning the car but having recently lost one of them, don't want the same happening again with the new ones.
Quote from: Ozzy on March 11, 2020, 19:47Anyone know what sized bolts I need for the hardtop blanking plates?
M6 (diameter) x 1.5 (thread pitch) x  10mm (thread length).
Serious bit
@Carolyn
M6 (diameter) x 1.5 (thread pitch) x  10mm. How do you do that?
Despite various searches of things the bay of E and giggle. I have yet to find a simple ready-reckoner tool that can identify what ever bolt/nut I have in may hand.
Dia - pitch - metric - imp - whitworth.
light hearted bit
Recently had call to go in to a local fixings shop. Been looking for an excuse to go in for ages.
I was looking for a nut to suit the spring bolt that fixes the back box to the cat. (malian related)
To my horror, I was served by a woman. :o
Me. I want a nut to fit this.
She. What is it, metric or imperial?
Me. Toyota.
She. Another one! She proclaimed to rest of the staff. (no idea what they want but expect me to sort it)
Which she did in no time at all.
Its an m10 1.25
I looked at her like a new best friend with her dirty oil stained hands from handing countless nuts n bolts, because muppets like me, don't know what they want.
Cannot wait to go back.
The shop is. All screwed up. Cavendish Road Leicester.
Customer floor space is 2-3m2 max. the rest is just stuff. The sort of stuff you need. If not right now, but you know you will.
I'm back there tomoz for some 50mm M10 bolts and tri lock nuts. (whatever they are) I'll ask my new best friend to explain.
SV-3
Quote from: Ardent on March 11, 2020, 21:15Serious bit
@Carolyn
light hearted bit
Me. Toyota.
Its an m10 1.25
I looked at her like a new best friend with her dirty oil stained hands from handing countless nuts n bolts, because muppets like me don't their what they want.
Here you go Jase:
https://www.amazon.co.uk/Thread-Gauges/b?node=6286355031
As for tri lock nuts - perhaps she meant Nylock nuts?
Eclectic - not electric
Sony WX-920BT
"Hardtop Cognoscenti"
"Stock Cubed"
"AirCon Aficionado"
"Keeper of the Beeper"
Ozzy
Quote from: SV-3 on March 11, 2020, 21:29Here you go Jase:
Thanks for the link. Have not seen that sort of thing before. They look a bit more complicated than I'm looking for.
Re tri lock. The nylock was my first thought, but they are different. I need to do a bit more research.
Will probably go with a split washer. (being as I've just bought 2)
Quote from: Ardent on March 11, 2020, 21:57
Trilock nuts are of all metal construction with three indents in an extra 'collar' of metal, that act as the 'lock'. Nyloc nuts use plastic, which ain't the best plan on an exhaust. Not only is 'Trilock' a thing, it's the correct thing in this application.
Quote from: Ardent on March 11, 2020, 21:15I looked at her like a new best friend with her dirty oil stained hands from handing countless nuts n bolts, because muppets like me don't their what they want.
I looked at her like a new best friend with her dirty oil stained hands from handing countless nuts n bolts.
Sounds like you were still giddy when typing it Jase.  :-))
I'm guessing you won't have one of these.... very handy.
https://www.ebay.co.uk/itm/New-6-150mm-LCD-Digital-Vernier-Caliper-Micrometer-Measure-Tool-Gauge-Ruler/133074753546?hash=item1efbdf980a:g:-usAAOSwMAxd8L4t
I have those calipers.  ;D
Pitch of thread is another thing
Quote from: Ardent on March 12, 2020, 18:52I have those calipers.  ;D
No excuse for not knowing diameter then!!
SV-3
Here you go Jase, apologies if I'm "teaching my grandmother etc etc":
https://en.wikipedia.org/wiki/ISO_metric_screw_thread
Sony WX-920BT
"Stock Cubed"
"AirCon Aficionado"
househead
I guess one way to measure pitch (without buying a pitch gauge) could be to keep a few labelled examples of most used pitches? There can't be more than a handful used by Toyota, can there?
Mikeymead
When you've worked with nuts and bolts for most of your life you can pretty much identify a bolt just by looking at it. It's like anything in life, there's no substitute for experience. I'm pretty sure that had a large part in Carolyn knowing what bolt it was.
Mikey is correct.  When you've handled as many nuts and bolts as I have, you just know by looking at it.
However, it is worth saying that almost all the M6 and M8 fasteners on our cars are 1.5 mm pitch. The original Toyota stuff is very high quality and tends to be flanged and plated.  Stuff from the fastener shop will suffice, but is often of lower quality.
Anything bigger tends to be finer thread (1.25mm and even 1mm) and with quite special lengths for plain section and threaded section.  These are not generally 'off the shelf' items at your friendly local fastener supplier, and have to be ordered from Toyota.
Which means it is always good to hold on to any spares generated by dismantling.
I've accumulated drawers full. ;D
