what size tyres for a set of 16"
Started by richbay, April 15, 2005, 08:13
richbay
what size tyres front and rear should i be running on my 16" TSW i have got second hand, many thanks
what width and offset?
I have 16" wheels and have 195/45/16 on the front and 205/45/16 on the back.  the wheels are 6.5".
I'm running 28psi in the front and 32 rear but i think i need to change it.  Any ideas??
offset should be written on the inside of the alloy, probably on one of the spokes
richbay
the wheels are 7.5J x 16 h2
Quote from: "richbay"the wheels are 7.5J x 16 h2
but whats teh offset?
richbay
to be honest im struggling to find the offset, stamped anywhere on them, i will have another look today.....
I am running 215/40/17 fr  & 235/40/17 rr (car not lowered) never touched arches, i think my rr rims are 17x9 et38? id have to confirm
what im saying is there should be bags of room for 16`s    s:D :D s:D
Quote from: "LLOYD"(car not lowered)
get that one sorted quick, definatley a must mod, sorts the bodywork lines out a treat, looks more squat
With the 17`s its looks dam sexy,,, can it possibly gat better???   s:D :D s:D
My worry is would it put more stress on the notorious top mounts????   s:roll: :roll: s:roll:
which? the lowering or bigger wheels?
richbay
i have read ET35-36 which i can only assume is the spacing, does that mean i need spacers or can they be used as is, i thought the mr2 spacing is 45
thats the offset, spacer won't help as teh lower the number teh further out from teh car they will sit.
I think it very likely they will rub on teh arches whatever tyres you use.
richbay
so they will have to be machined down then
in theory yes
however it's all down to the individual wheel you have as to whether it is safe to do so.
personally from a 35 to a 45 means taking off far too much to be safe and I wouldn't.
best bet is get shot and get some wheels that are designed for teh application.
Useful information on wheels -
When purchasing wheels there are a few things to take into consideration,
1. Size of rim.  This is the obvious one. I believe 17" is the biggest on the market (without causing any problems)
2. Width. Again obvious. I think im on the max here i have 8" with 215 tyres on the front & 9" with 235 tyres on the rear.
3. Stud layout. this is known as `PCD` it is the distance between the bolt holes, ie MR2 Roadster uses 4x100 PCD (4 bolts spaced at 100mm). & a VW Golf GTi MK4 use 5x100 PCD (5 bolts spaced at 100mm).
4. Offset. this is known as ET number. This is how far under the car does it fit? As Markiii correctly advised the lower the number the further out the wheel will be.
Important your offset in most cases WILL change from that of the original wheels, so dont go by your 15" wheels offset.
The offset number can be found in one of two places, either between the bolt holes or on the rear of a spoke.
5. Stud /Bolt type. This one is often over-looked, it is to do with the taper of the bolt / stud versus the taper of the hole in the wheel. These two must match, there are a few types so always check that the taper of the stud / bolt fits comfatbly & flush against the alloy & the thread marries up to the hub ok.
Hope the above helps.
With 16" tyres id say go for 215/40zr16 on the front & 235/40zr16 rear.  s:D :D s:D    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:
Quote from: "LLOYD"With 16" tyres id say go for 215/40zr16 on the front & 235/40zr16 rear.  s:D :D s:D    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:
way way overkill on a stock roadster
also on his 6.5" rims theres no way a  235 will fit properly, you'd be pushing on a 7"
Sorry Markiii i didnt look at his wheel size because i agree with you totally on the DO NOT shave 10mm off the offset, i think he should get rid and start again. What i meant was those would be the max sizes for the car not those rims.   s:oops: :oops: s:oops:
in which case true  :-) :-) :-)
however unless going turbo 235 is just wasting money and adding weight on an NA it will actually slow you down. Especially when adding the weihgt from teh extra width of teh rim needed to cope with it.
HMM
Got to admit tho my 2 looks real nice from the rear with 235`s!   s8) 8) s8)    s:D :D s:D
ok, I'll grant you that.
this is where performance and appearance mods can clash.
just depends on what your after
