Death to the pre-cat?
Started by Wrightly, April 15, 2005, 16:22
Wrightly
Hey,
after recently replacing my o2 sensors when they were shagged with a blown engine, I have noticed an increase in performance and the engine sounds better, but am still experiencing problems.
Just before the redline the engine warning light flashes and the engine splutters. Also, it still doesn't seem as fast as it used to be, and feels as if something is restricting something somewhere.
When my engine blew and I had it reconditioned, Mr T had to put on a new cat as well due to all the hydrocabons etc blocking and collapsing it. However, the monkeys never replaced the o2 sensors( leaving to me removing some totally carbonised ones) and I get the feeling they would have left the pre-cat as well - which I think is now causing me problems.
If the pre-cat was restricting the exhaust, could this be enough to cause the engine problems at high revs? And also my exhaust note has sounded louder since I got it back.
Another thing is that when the people who reconned the engine returned it to Toyota for fitting, they broke the vvti controller in transit. I was adament that they replaced it with a japanese version (due to my car being an import) but they might have cut corners and put on a UK controller. Could this be making the exhaust note louder, opening the valves that little too early and messing up at high revs? The engine warning light also comes on if i'm going up a hill and using low revs. Any ideas?
If either of your pre-cats have broken away, looking at the exhaust volume sticky thread, that would indeed make the exhaust sound louder.
Can you remove your 02 sensors and take a look to see if they are still intact?
Wrightly
Yeah, When I replaced the sensors a week ago I had a look. I couldn't see the right hand one due to the angle, and the left hand looked kinda lumpy, a bit dirty, but not as carbonised as the sensors.
