Yaris Wishbones
Started by justinread72, April 17, 2020, 10:13
justinread72
Can someone confirm that Yaris Wishbones fit as they sure look the same ? oh and a fact is that Blue Print make the Toyota ones
Quote from: justinread72 on April 17, 2020, 10:13Can someone confirm that Yaris Wishbones fit as they sure look the same ? oh and a fact is that Blue Print make the Toyota ones
Yes they do fit, but a couple of members have had problems with the ball joint boot splitting.  Almost certainly old stock, sold at rock-bottom prices. Pay a little more and consider the seller's rating.
As Blueprint are aftermarket specialists, I doubt that they are an OEM supplier, but that's merely my opinion.
justinread72
Quote from: Carolyn on April 17, 2020, 10:18
Someone had some blue print ones on here under the sticker was stamped Toyota. LUK supply Honda clutches Borg warner supply Honda timing chains. Car manufactures cannot make everything I have worked with jaguar landrover I was a supplier for them as for what to do I am going to do what I did before now whiteline and super pro bushes will make them better then OEM
Quote from: justinread72 on April 17, 2020, 19:56
Couldn't agree more on component suppliers.  I've made the same point before.  I just though blueprint were a little different.
Chilli Girl
Funny enough the gasket I brought was from Blue print.  Showed it to a guy who's a mechanic and he said if it was him, he wouldn't fit it as it was best to stick to a Toyota one.  He thought that Blue print had gone off abit over the years and products were not as good as they were. :'( Now, I have a gasket I don't know what to do with!
Quote from: Chilli Girl on April 17, 2020, 20:33Funny enough the gasket I brought was from Blue print.  Showed it to a guy who's a mechanic and he said if it was him, he wouldn't fit it as it was best to stick to a Toyota one.  He thought that Blue print had gone off abit over the years and products were not as good as they were. :'( Now, I have a gasket I don't know what to do with!
As I understand it Jane your cars cam cover is currently leaking oil. I understand that it is not a big or difficult job to do and that you intended to do it yourself. As you have a replacement gasket, albeit a pattern part, this will either cure your leak or it will not. If it does you have won. If it lasts you have won again. If it doesn't work, you will be no worse off than you are now but will have spent/ wasted some time doing the job. I doubt that you have good cause to return the gasket unless it is damaged, unless the supplier has a money back for any reason warranty in which case that would be a partial solution. Partial because you would still have the leak.
