Rear crash bar
Started by pistol pete, May 23, 2020, 09:26
pistol pete
Hi all
All the lightweight people out there.
Rear crash bar. Currently not running one on my car. Because race car.. but question
Its so far back I cannot see it adding any positive effect to the handling. As it's well behind the subframe and the subframe is solid and ties the two legs together as does the top strut brace.
What are your thoughts.. it's not driven on road before anyone says about that 😁
Have any affect I just see it as weight loss from rear of car which is always positive.
Agreed. There's a subframe there and also there's the top subframe as well, welded in.
I see race cars use an aftermarket "crash bar" to mount the wing and or other exhaust/aero stuff.
But... In a crash, I guess it would stop your expensive engine bits from getting smushed
Amarlborough
Ropey racing have produced a rear crash bar (don't know if it's lighter than standard) with the idea of it being modular with their other products.
https://www.ropeyracing.com/
Being un incurable weight weenie have looked at it several times and... have concluded that it does add structural rigidity.
Have a good look at the rear suspension: Not all forces are supported by the subframe.
Same thing engine.
You can easily see that the rear transverse beam is very much needed but it sits only at the top and the crash bar closes the cube at the bottom.
Bcxbcx
Also it links the two sides of the car between the towing eyes, and therefore it probably helps to spread the load across the back. Without the bar if you tried to tow the car backwards, it would possibly damage something.
2000 W PFL in black
pistol pete
Thanks people's I might make a bar to go across ...I'll have a looks!
Smithy
Quote from: Amarlborough on May 23, 2020, 11:19Ropey racing have produced a rear crash bar (don't know if it's lighter than standard) with the idea of it being modular with their other products.
their V2 aluminium bash bar looks like it will do the job nicely. you can bolt on a wing and I think they are going to produce a rear diffuser at some point.
03 Astral black MR2 OEM+
pistol pete
Expensive though!!
I'll make my own. And I'll try with and without at brands see if any difference .
Spoke to rogue most people don't run anything there in the championship
