Body kit fixing
Started by Zxrob, June 3, 2020, 10:03
Zxrob
Guys/Girls
Got some body kit parts to fit, need to trial fit, prime and paint, I will be fixing with double sided tape, tiger seal and self tappers where required, question is, there are loads of tapes about, any recommendations from past experience
Cheers Rob
Adventure before dementia 😁
I am aware that 3M produce a range of double sided tapes that are use in the Car manufacturing and other industries:
https://www.3m.com/3M/en_US/bonding-and-assembly-us/double-sided-tape/
I had a bonnet lip spoiler on my T4 van for a while. The centre section had 3m tape on, the 2 angled ends (that followed the sweep back of the bonnet) had unspecified tape on.
The 3m tape stayed on fine and I actually broke the spoiler pulling it off. The end sections had both come loose though.
There are lots of 3m copies though so make sure you are buying genuine 3m (its expensive!).
My bodykit is held on with just tigerseal and a few tiny self tappers on the ends of the skirts and no problems so far....
I've given up trying to get my new lip to fit where I want it to with enough confidence that it won't pull away and break the Tigerseal.
So I'm going to bolt it on and make a feature of the bolts, as you do...
Zxrob
Cheers folks
Was looking at the 3m, I've used double sided tape on other things over the years, some are ok, most are poor
Rob
Smithy
Quote from: Call the midlife! on June  3, 2020, 11:00I've given up trying to get my new lip to fit where I want it to with enough confidence that it won't pull away and break the Tigerseal.
any pictures available?
03 Astral black MR2 OEM+
Quote from: Smithy on June  4, 2020, 14:22
Not as yet, it's work in progress, or lack of progress the last couple of days. Won't be any movement on it for a while now either due to family commitments but hopefully one day.
