2zz induction help please
Started by MrGreen, June 4, 2020, 15:19
MrGreen
Hi all, help please.
Several 2zz swap induction kits have an adaptor for the vacuum hose including the mwr and ppe.
If using the EliseParts maf adaptor pipe, what do I do with the vacuum pipe? Help please.
Hi there
Just block it off with a rubber cap and small jubilee clip. Cap size depending on the size of the pipe I guess.
Alternatively
https://www.elise-shop.com/hurricane-induction-kit-for-vvti-engine-elise-111r-exige-s2-federal-elise-p-250.html
or build one:
https://www.eliseparts.com/shop/engine-br-gearbox/induction-exhaust/induction/toyota-air-feed/
MrGreen
Quote from: shnazzle on June  4, 2020, 16:29Hi there
Thanks 👍
Why do the mwr and other kits come with a connection for it though if you can just blank it off?
Quote from: MrGreen on June  4, 2020, 16:32
Thanks 👍
Sorry I adjusted my post above with more info :)
MrGreen
The elise parts link is the product I have. My question is why it doesn't have a vacuum pipe connection when the other products do? And as such if you just blank it off, then why do the others have it at all?
ah right. It depends on the throttle body.
the cable throttle has the input on the throttle body.
I believe the drive-by-wire throttle body does not. So it needs to be elsewhere. I could be wrong...usually am hahaha
Options are induction pipe and intake manifold.
Also, a lot of these pipes are also compatible for use with turbo for blow-off valves.
I remember i had one once and it came with a blocker, in case you didn't need it.
MrGreen
Ah I see, thanks for the info very helpful. 👍👍
I think I've totally misread your question...
It's the inverse of what I thought it was, in which case my earlier advice needs to be ignored thoroughly as this will cause issues!
But I sort of covered it earlier... there should be an input on the throttle body that you connect it to.
MrGreen
I got you. I don't have the car at the moment so I was unable to look for myself and suss it out.
Thanks 👍
