2001 Blue
Started by panderoo, June 5, 2020, 17:42
panderoo
2001 Blue
Just acquired, totally standard and very clean, original hood in perfect condition.
Has had UJ changed and a recent clutch.
Quickly machine polished today before the rain set in.
Repair or upgrade parts to follow.. >:D
Quote from: panderoo on June  5, 2020, 17:422001 Blue
Gotta love a good clean example of a pre-fl.
Seeing a nice facelift is like "oh that's nice". Seeing a great pre-fl somehow carries a lot more weight
Hello and welcome, @shnazzle sums it up nicely.
Enjoy.
GodalmingMR2
Best colour!
panderoo
Thanks for the comments, I'm quite fond of it already.
panderoo
Things are escalating quickly
Stripped down ready for pre-cat removal.
panderoo
Test fit of a 3D printed knob..
Not sure on this to be honest as it needs some work around that area for it to look right.
Quote from: panderoo on June  8, 2020, 21:41Thanks for the comments, I'm quite fond of it already.
The feeling grows. :)
Quote from: panderoo on June  8, 2020, 21:46Test fit of a 3D printed knob..
HOLD THE PHONE!
Can you clarify 3D printed knob.
As in.
A. You ordered and bought one? Or.
B. You designed and printd yourself?
Quote from: GodalmingMR2 on June  5, 2020, 22:32Best colour!
Nearly. ;)
SV-3
Eclectic - not electric
Sony WX-920BT
"Hardtop Cognoscenti"
"Stock Cubed"
"AirCon Aficionado"
"Keeper of the Beeper"
panderoo
Quote from: Ardent on June  8, 2020, 21:52
HOLD THE PHONE!
As in.
They are on EBay from a guy in Doncaster.. search M12x1.25 knob and it's the one with a photo of 4-5 different coloured knobs.
Initially I ordered one really just to have a look as I'm quite interested in 3D printing.
Having looked at the product, I think it would be quite easy to make with my brothers 3D printer so I may take some dimensions and look into making my own design soon.
very much on the outside looking in. But the concept of 3d printing.....
panderoo
This is very low level as far as 3D printing is concerned by today's standards.
It's the future and the progression and capability currently is mind blowing while still very much only the being in its infancy.
Quote from: panderoo on June  8, 2020, 21:44Things are escalating quickly
If you have read about this procedure I do hope that PPE was mentioned. The catalyser is a mix of materials that you don't want to be breathing in nor getting in your eyes.
If you were aware of this OK, if you weren't please be advised.
panderoo
Quote from: Joesson on June  8, 2020, 22:47
I wasn't so thanks for the heads up 🙏
I have bought a Toyosports manifold so I may just use that instead of going through the clearing out of the cats.
Are they worth fitting or would I be better to stick with the cleared out OEM manifold ?
If there is nothing wrong with the pre cats. Save yourself the bother and run as is.
panderoo
I had a quick look over the weekend and they look to be starting to break down.
I would rather take the lot out or fit the Toyosports mani for peace of mind, but it would be good to hear any views on if there is any advantages of the Toyosports..?
tricky1138
Quote from: panderoo on June  9, 2020, 08:57I had a quick look over the weekend and they look to be starting to break down.
Replace with the Toyosports is my opinion. Thats what I'm doing. There was talk a while ago of someone noticing a difference with the gutted manifold compared to a toyosports / equivalent. Something to do with the empty pre-cats chamber not being good for gas flow.
I'm sure @shnazzle will be along shortly to explain better.
Seven or so years ago the general consensus was to remove the pre cat material no matter what. A guy on Spyderchat was an advocate of retaining the cast OE manifold as it was of "high quality".That is what I did.
Since then, there has perhaps been a better understanding of the sequence of and reason for the pre cat break down and this has been well discussed on here.
Many people now favour replacing the OE manifold with varying qualities of tubular stainless steel manifolds, such as the "Toyo".
What the measurable performance or other benefits to the fitting of a tubular manifold is now the topic of some debate, as is the subsequent wrapping of the aesthetic, shiny stainless with heat resistant/ retaining tape.
As the saying goes,  you make your choice and pay your money.
There is little debate that whatever choice you make, the manifold to head and manifold to main catalyser gaskets, should be replaced with genuine Toyota gaskets.
panderoo
Interesting.. what's the current debate on wrapping or not ?
I have ordered wrap, but would again be interested to know thoughts on if it's worth adding or not.
Performance wise I'm not expecting anything, but it has just arrived and the flanges look to be of nice thick quality material.
I do have genuine gaskets on order 👍🏻
tricky1138
Debate on wrapping is whether or not the manifold can cope with the extra heat that wrapping does to it.
According to some, wrapping causes cracking to cheap manifolds (and I include toyosports in that category) but I agree that it helps keeping engine temps down.
I've never found an aftermarket manifold where you can put the original heatshield back on - you would think they could get the holes in the right place!
I've wrapped my new manifold, and I wrapped my old one too.
Out of interest does yours come with brackets to attach to the block at the bottom? As thats anoter reason why some crack.
panderoo
No brackets for anything.
Looks like I could be better leaving the wrap off ??
tricky1138
Quote from: panderoo on June  9, 2020, 11:28No brackets for anything.
I'd still wrap it.
