Top mounts??
Started by Anonymous, April 21, 2005, 16:28
My N/S/F tyre is scrubbing out really bad on the inside, it is also happening on the other side but only very light.
I had the tracking tested with a Hoffman 4 wheel laser line and it was cock-on.
All the ball joints & bushes are ok so this must leave just the top mounts to be at fault?
Has anyone had experience of these? (I am sure loads of you?)
What i would like to know is when i take off the front under bonnet cover to look at them is it going to be obvious in the respect of visible wear?  s:roll: :roll: s:roll:
Lloyd
GSB
If all the joints and bushes are ok, and the geometry is all fine, then I suggest you dont have a problem with the car at all. More likely I would think, is a an over exuberance when it comes to roundabouts...  s:wink: :wink: s:wink:
hmm
Its one of them `yer gotta see it` kinda tyres, if you saw it you would say geometry or summat...   ive tried different tyre pressures etc, no good and also its on the inner side as apposed to outer so the roundabouts thingy is harder to believe?   s:roll: :roll: s:roll:
with the camber setup and toe in on teh roadster you will always have more wear on te inside edge, particularly if you attack roundabouts with zeal.
I'd agree with Grant, if teh alignment is correct it's not your top mounts.
HMM
Really????  Its strange innit!
must admit i rarely slow down for them round circles of grass!!!   s:twisted: :twisted: s:twisted:
