Won't rev
Started by Garfy, August 5, 2020, 17:21
Garfy
So, when parked in neutral, push accelerator down, goes up to around 6K revs, drops down to 4K and get black smoke from the exhaust as if it's over fueling.
Water cooled T25 turbo
Air to air intercooler
440cc injectors
ECU and electronic boost control
2.5" sports exhaust with twin tail pipes
Garfy
Compression test was good
440cc injectors
This is a very "out there" one but there's nothing fouling your throttle pedal/cable is there? My floor mat once found it's way over the pedal and wouldn't let me give it full beans.
Garfy
Quote from: Call the midlife! on August 31, 2020, 18:00This is a very "out there" one but there's nothing fouling your throttle pedal/cable is there? My floor mat once found it's way over the pedal and wouldn't let me give it full beans.
If only 😁
No, it's engine related, it revs or tries to initially, then drops down to 3k it's fueling as if you got the pedal down (hence black smoke, petrol smell and black sparkplugs (2 months old)) with an obd reader connected it shows misfires across the cylinders because they're getting too much petrol (I believe). 🤔
440cc injectors
Quote from: Garfy on August 31, 2020, 17:31So, we've swapped MAF, coil packs, spark plugs, made no difference  ::)  Checked the fuel filter currently checking vvti solenoid and cleaning which works ok. 😤🤔 Mechanic is a little stumped
Got a spare engine you can swap in...
Garfy
Thanks John I'm only on 70k with this one, can't give up on it yet 😥 think when it does go it will be time for a 2zz 🙃
440cc injectors
Sounds like a sensor issue.  I can send you a crank sensor and a cam sensor... Known working ones.
Garfy
Quote from: Carolyn on August 31, 2020, 20:07Sounds like a sensor issue.  I can send you a crank sensor and a cam sensor... Known working ones.
Thanks Carolyn they would be gratefully received.
The little shop
4 station road
Kings Langley
WD4 8LF
Let me know how to pay you for them x x
440cc injectors
Seeing the problem solved will be ample payment.
Cap
My favorite CPS issue was a Tach Reading with the Key on, and the engine not running..  Ended up Strapping a 2K resistor across the Input to the ECU leads, and the problem went away..  Car ran better too!
Cap
mr2garageswindon
What is the coolant temp sensor reading on the scanner? Fuel trims? Possible vac leak..
Garfy
Quote from: Cap on September  1, 2020, 00:08My favorite CPS issue was a Tach Reading with the Key on, and the engine not running..  Ended up Strapping a 2K resistor across the Input to the ECU leads, and the problem went away..  Car ran better too!
Cap
Thanks Cap, but I have no idea what you wrote, sorry.
Could you be saying my ECU has turned into Hal and needs some electric shock treatment?
440cc injectors
Garfy
Quote from: mr2garageswindon on September  1, 2020, 10:21What is the coolant temp sensor reading on the scanner? Fuel trims? Possible vac leak..
I can get them checked, could you advise what they should be?
I have a friendly mechanic who does most my work for me, unfortunately this is his first 2 to work on.
Thanks for the input, I've already passed it on 😁
440cc injectors
Garfy
Quote from: Carolyn on September  1, 2020, 11:58On the way.
Many, many thanks Carolyn, there'll be a donation on its way to the club, that way we all benefit from your generosity x x
440cc injectors
Garfy
Forgot to say @Carolyn all received thank you x x
440cc injectors
Quote from: Garfy on September  1, 2020, 20:31
Very generous donation received. Thank you both! That's hosting for a couple months.
Garfy
Hmmmm, after all that :-X  :-\
Tubing from air intake to cone filter was  kinked, hence no air getting to engine.
440cc injectors
Quote from: Garfy on September 25, 2020, 09:34Hmmmm, after all that :-X  :-\
.... Aftermarket intakes.. I tell ya..
I've got to ask, how did you end up getting some 75mm tubing that badly kinked???🤓
@Garfy
10/10 for fessing up.
You must be feeling very mixed emotions!
Garfy
Quote from: Joesson on September 25, 2020, 11:25@Garfy
Needs to be on here in case anyone else has a similar issue 😥
 @Call the midlife! It was that tinny tubular stuff you take from the vent and goes to an enclosed air filter 🤯😤🤮😖
440cc injectors
Quote from: Garfy on September 25, 2020, 13:38
Right, got you, I've got two lengths of that running from my side scoops into areas of the engine bay so know how easy it is to crush. But they're not connected to anything, just ran it in before I bonded the side scoops on, the mushroom filter is hard piped with silicone sleeves.
Fair play to you for fessing up, you can have my trophy from last year.👍🏻
Garfy
My list is spare bits is building up ;D
MAF
4 coil packs
Cam sensor
Crankshaft sensor
Throttle body
MAF spacer
4 X injectors.
All ready for next ding day auction  ;D
440cc injectors
