HELP - BATTERY
Started by Anonymous, April 22, 2005, 09:32
Left work yesterday and my battery was completley flat  s:evil: :evil: s:evil:  , Called the AA and was told that I need a new Battery asap as it did not pass their test.  I'm not sure exactly what i am looking for due to weight etc.  Will Halfords have a decent replacement or are there any on the market which are lighter than stock?
I would be grateful for any advice so that i know what i'm asking for when calling around later.
Also, when putting it on charge this morning, I noticed there was no engine coolant and no oil!!!!!!!!!!!!!!!! (There was the last time I checked)  Am i correct in thinking i need to get the red coolant from toyota and 5-30 oil??
Many Thanks,
Viggs
techincally any ethyl glcol coolant suitabel for aluminium engines will be fine.
but personaly yes I'd stick with MrT
oil is bad check those precats.
I've just bought an optima Yellow Top replacement battery, it's a bit lighter but mainly for it's deep cycle abilities as my car stands a lot these days.
it wasn't cheap.
if weight is your big issue look at teh genesis range,
Thanks Mark,
I will pay Mr T a visit later for the coolant and think i will check the oil on a weekly basis just in case it is the dreaded pre-cats.  Stay away from Magnatec?  I used the Halfords brand the last time (green container) and the car ran fine.
Weight isn't a big issue but didn't know whether there are any out there that maybe better than the stock.
Maybe a trip to a Hi Q garage or quick fit will sort it.  I'm expecting to pay around £40?
Cheers,
Viggs
ref the oil, I'd avoid magnatec liek the plague it's evil stuff.
but check your precats don't rely on your oil level.
expect £50 ish for teh battery, Grants posted some details for Varta ones a while back search for "Battery Specs"
yellow top cost me £177 which as I say is a bit OT for most people.
Genesis are circa £80 but half teh weight of stock.
Quote from: "markiii"Genesis are circa £80 but half the weight of stock.
I got a PC545 from US (eBay) and it was only $50 and some $25 for (ground) shipping. It was actually cheaper than a normal sized battery over here, gotta love the weak USD  s8) 8) s8)
