2zz piston specification
Started by Gaz2405, September 7, 2020, 18:58
Gaz2405
Now bear with me here, but.....
Has anyone got the specs for 2zz pistons, in terms of dims from centre of pin to top of piston. Or does anyone have a stock 2zz piston they could send me.... 😉
As I'm having issues getting an engine built to the specification I want without sending the block away to darton in the US.
I've started to think about how I can use the parts I currently have.
Now the 2zz has 82mm pistons, and I also have a set of 8:8.1 82mm forged pistons although for a 1zz.
Rods I don't have a problem with getting another set.
So what I'm looking into doing is running the pistons I have in a 2zz block with a new set of rods.
Reason being it's an easy engine swap and may end up slightly more cost effective thatn sending my 1zz block of for machining and higher tuning potential.
The engineer in me says this should be a possibility, plus I'd end up treating myself to some better engine management which was always the plan with the built 1zz anyway.
Gaz2405
Hmm further investigation looks like piston crown design maybe a limiting factor.
KRAMSNEHPETS
You can get darton sleeves done over here
2004 Red edition. 2ZZ engine with Rotrex 30 94 supercharger,90mm pulley. Link Storm ECU. Charge cooler. Custom Meggalian exhaust.Uprated fuel pump, regulator and rail.840 injectors.323 BHP at the hubs. Meistier coil overs. Matt under body brace. Front and rear, upper and lower braces,list goes on...
Gaz2405
Quote from: KRAMSNEHPETS on September  8, 2020, 00:05You can get darton sleeves done over here
So far everyone I've approached don't deal with this engine or if they do, it goes off to the states for it doing.
I've potentially found a company that do, but they want to see the block and sleeves first. They're a sleeving specialist, but have never done a 1zz.
Mark A
Can you pin the block rather than new liners?
Gaz2405
Change of plans now, just picked up a sleeved 2zz block :)
