Clutch Fluid reservoir
Started by ade1971, October 3, 2020, 11:35
ade1971
Hello just a quick question
Where the clutch Fluid reservoir located as I need to change and check brakes and clutch Fluid and can't find it
Quote from: ade1971 on October  3, 2020, 11:35Hello just a quick question
Under the front plastic cover, next to the brake master cylinder.
ade1971
Quote from: Carolyn on October  3, 2020, 11:37
@Carolyn , I did know that, but if I hadn't I would have to go outside to the garage to get the hand book and then find the relevant section. All in that would take rather longer than the 2 minutes you took to answer ade1971 's post.
Impressive!
