Stereo / Speaker upgrade
Started by J4ck100, October 7, 2020, 15:37
J4ck100
Hi all,
I am looking to improve the sound of my 2006 MR2 audio set up as I find it inadequate (I like my music).
I understand that both the OEM headunit and OEM speakers are limiting factors to sound quality. Problem is, I am a big fan of OEM look interiors and don't, ideally, want to replace the OEM headunit.
My question is therefore, is it worth upgrading the speakers only / is the OEM headunit capable of delivering a decent punch to a good set of aftermarket speakers, or must one replace both to obtain the desired outcome?
Thanks,
Jack
I'm sure others will disagree but if you don't bin the Fisher price stereo upgrading the speakers is a waste.
I'd save my money fit a rorty exhaust and listen to that instead.
As said; you will definitely notice a difference replacing the head unit. That's the bottleneck.
I added an active sub and better unit, with stock speakers. That did the trick for me for years. I recently upgraded speakers as well
MRSwede
Upgraded speaker and a amplifier is another way to go.
Bossworld
Head unit made the biggest difference for me, closely followed by a sub.
I subsequently swapped out my speakers for some uprated components but above 40mph it's still largely drowned out.
If you don't want to replace anything then sound deadening the doors will make a difference.
J4ck100
Thanks all!
Sounds like a head unit is a requirement.. I do miss my mx5 with speakers embedded in the headrest!
Any recommendations as to a good fitting head unit?
Mr Lazy
Just a thought...a bit drastic, but I wonder if it is possible to swap the seats to get the desired speakers in the headrest.
Quote from: Mr Lazy on October 12, 2020, 21:47Just a thought...a bit drastic, but I wonder if it is possible to swap the seats to get the desired speakers in the headrest.
S2000 seats have been swapped dont they have headrest speakers?
Thing is it all adds weight.
Says the 105kg chubbster.
tom256
Quote from: J4ck100 on October  7, 2020, 15:37I understand that both the OEM headunit and OEM speakers are limiting factors to sound quality. Problem is, I am a big fan of OEM look interiors and don't, ideally, want to replace the OEM headunit.
Thanks,
Jack
Buy Mark Levinson Speakers from Lexus IS250. These are direct replacement, premium quality, and OEM :)
It is best solution for MR2.
Tweeters will not fit, You need to do some modification. :/
You can also use Dynamat Superlite, +0,73kg for each door, but it is worth.
Stock speaker weight: 0,80kG
Mark Levinson weight: 0,75kG
Toyota MR2 Roadster 2005 TF300 Silver Streak Mica
Team Impul NS-GT2 '17
Zero header + Zero cat + TTE Exhaust
TRD Door Stabilizer
Denso TT Iridium
Quote from: tom256 on December 22, 2020, 09:57
Thanks,
Jack
Stock speaker and bracket weighs 728g.
Do what cyclist's do and wear headphones.
Is there any other kind?
Be a shame to spoil the ninja stealth mode with some reflective headphones.
LeRich
The standard speakers are pretty decent for OEM. I replaced my duff PFL Sony with a single DIN Kenwood head unit and while it's not amazing, for a small flimsy soft top car the setup sounds good enough.
Quote from: LeRich on December 27, 2020, 22:10The standard speakers are pretty decent for OEM. I replaced my duff PFL Sony with a single DIN Kenwood head unit and while it's not amazing, for a small flimsy soft top car the setup sounds good enough.
You think the PFL is duff. You should see the FL Fisher Price.
Quote from: Ardent on December 27, 2020, 23:29
Totally agreed.
LeRich
It was duff as in faulty - when it worked properly it was decent. I loved its retro looks and would have kept it otherwise.
