Non standard coolant leak.
Started by Call the midlife!, October 15, 2020, 16:58
Quote from: Carolyn on November  1, 2020, 13:02It never occurred to me that you were putting the seal in wrong.
Doh!
Which does  illustrate the difficulty of remote diagnosis in general and as is particularly and unfortunately, the case now with GP's!
Why would it? You can't always account for stupid...😆
I blame the official, exploded assembly  diagram I was following...
Quote from: Call the midlife! on November  1, 2020, 13:11Why would it? You can't always account for stupid...😆
No wonder you had difficulty if the diagram had exploded😉
Quote from: Call the midlife! on November  1, 2020, 12:55Don't worry, I've put 4 IPAs in the fridge for later!
I could've styled it out with a loose mounting post or something but what's the point? Nobody learns if we all get it right first time, the blinkers were well and truly on with this one though.
Cheers!😆
IPA!
Champagne is on offer a Sainsbury
Lovely dry garage floor this evening. And no coolant in the expansion tank so more bleeding to come.
m1tch
Any reason you are using a plastic neck rather than a metal one?
Quote from: m1tch on November  3, 2020, 16:01Any reason you are using a plastic neck rather than a metal one?
The vast majority are plastic.
Standard issue, if it ain't broke... Like the rest of the car 🤓
