Whiteline arb's moved off centre
Started by jamfe355, November 3, 2020, 17:06
jamfe355
Hi all,
My Whiteline arb's have moved off centre, it seems to be reasonably common on these.  I will purchase some of these to stop this.
https://ukwhitelineperformance.com/collections/lateral-lock/products/kll118-lateral-lock
 Question is.... do you think the Yellow poly bushes that came with the bars are still OK after 30,000 miles or have other members replaced theirs around this age/mileage?
2002 balck MR2, Eibach springs, Apexi exhaust system, corky\'s, cusco front and rear brace, lower front tie bar,  Bmc carbon air filter plus some minor tweeks.
I can't answer your question through experience, but recently bought a Whiteline for future fitting.
I've since seen a topic discussing the Whiteline & a new buyer was told to chuck the included bushes & fit Superpro instead.
tets
I've also heard the same as Gaz so bought Superpro for when mine arrive - You can also buy an additional "thing" from them to stop this happening - it's essentially a collar that clamps to the bar at the sides of the mount
I've not bought these, mainly because I forgot so will probably make some!
