Koni -- H&R
Started by Bad Dog, December 4, 2020, 23:17
Bad Dog
Did you read
 "Front Dampers are Inserts. Rear Dampers are inserts. In a few instances Original Damper Housings may require cutting"
Look up youtube. "Koni cut-a-strut" I think it's called.
Yes, some have fitted them......    https://www.mr2roc.org/forum/index.php?topic=66831.0
Bad Dog
Quote from: Gaz mr-s on December  4, 2020, 23:27Did you read
Yep just read through it........sounds like just what I'm after .
Tomo70
H & R springs are far better than the tiens and lower the car to a reasonable and useable height. I have no problem with speed bumps and the car sits well
AdamR28
Have the Konis on my track car, and have used them on other cars. Really rate them for road, B road blasting, and occasional track.
