Radiators
Started by Bad Dog, December 5, 2020, 20:30
Bad Dog
Ok,
    So my radiator is looking very sus.
After having a bit of a search I've found out that you can get a new radiator for £38.00 or £260.00 does anybody have a link to a decent radiator that I can buy ? something of quality that i can replace and forget about   ;D
The cheap ones last long enough for the price.
If you've still got the car in 5 years buy a new one and flush the coolant.
I bought and fitted a CoolpartsUK radiator (ebay brand name for Advanced Radiators) when I first got the car in 2014. It's still there. Still not leaking. So for 35 quid I reckon I've got my moneys worth :)
What ^^^^ they said.
Is it the old drain plug that people recommend you swop over to the new radiator when you change them?
Quote from: Topdownman on December  5, 2020, 23:01Is it the old drain plug that people recommend you swop over to the new radiator when you change them?
Yup. And put a new thicker o-ring in
Bossworld
Yes, and check the o-rings, as unless they've updated them, they're the wrong size and already deformed.
Bossworld
scm2004red
So as a matter of interest where are all these O rings, I can think of bleed screws/drain plugs, where else are they?
MR2 Red Edition 2004
Porsche 924 1984
Quote from: scm2004red on December  7, 2020, 14:05So as a matter of interest where are all these O rings, I can think of bleed screws/drain plugs, where else are they?
That's where they are.  Bleed screw and drain plug (identical).
normanh
I have installed a Coolparts Rad back in June 2016 still going strong.
Norman
