wheel types /
Started by HunwickFlyer, January 1, 2021, 17:02
HunwickFlyer
Hi , i am a new member having just bought 2002 , i cant find anything on original wheels and my o/s front is corroded not had to anyone yet to check but would like some info on the wheel types.
http://www.midshiprunabout.org/sources/oem-wheel-specs/
September 2002 – End of line All Markets
Pre and Face lift Fronts
Width 15" x 6"
Offset = et45
PCD = 4 x 100
Weight = 14.6 lbs
Front Tyres (Bridgestone RE040 or Yokohama A043, USE MATCHING SETS)
185/55/15 V81
Pre Face lift Rears
Width 15" x 6.5"
Offset = et45
PCD = 4 x 100
Weight = 15.2 lbs
Tyres 205/50/15
Face lift Rears
Width 16" x 7"
Offset = et45
PCD = 4 x 100
Weight = 15.2lbs
215/45/16 W86
Have a look in the glove box. You might find a little sticker that shows what should be fitted.
HunwickFlyer
Hi , thanks for the info snow and hard frost here since it came to roost not been able to lie with yet , it has Dunlop Sport  maxi rears 215/45/r16 and Excelena B ? 185/55 /15 xl front.When all the suppliers are back to work ,will have a look at the wheel replacement.
Quote from: HunwickFlyer on January  3, 2021, 21:17Hi , thanks for the info snow and hard frost here since it came to roost not been able to lie with yet , it has Dunlop Sport  maxi rears 215/45/r16 and Excelena B ? 185/55 /15 xl front.When all the suppliers are back to work ,will have a look at the wheel replacement.
The OEM wheels are hard to beat for weight.  May I suggest you contact Mr Sloan (our affiliate breaker?  His prices are very reasonable.
HunwickFlyer
Cheers, where will i find Mr Sloan please ?
Home page:
'Specialist Breaker and Parts Suppliers.'
