What's behind the liner?
Started by Carolyn, January 3, 2021, 14:24
Seeing as I ain't goin' nowhere right now, I put the car up on the ramp to give the front end an inspection and clean-up (and to push out a ding in my bumper).
I decided to do a proper job and take the arch liners out.
Glad I did.  The cavities behind the liners (just in front of the door bottoms) were utterly jammed full of damp road grunge.  I was shocked to see how much came out when I took the compressed air to them.
It's a rust issue waiting to happen..
I gave it all a good clean, then some zinc primer and then some silver wheel paint.
So, boys and girls, if your car is a 'keeper' it's a job well worth doing.
Pic of the location:
puma2
 :) the feeling you when say sod this lets just get on with it a make the best we can  :)
then finding bits that need cleaning/oiling and just a dam good clean  up 8)
then when all done and you sitting down later relaxing after the hard work and effort put in :)
there is no better feeling than a Proper Job  :)  :)  :)
fair play you do love a good Tinker and Fettle
Quote from: puma2 on January  3, 2021, 14:58:) the feeling you when say sod this lets just get on with it a make the best we can  :)
Nothing like a tinker and fettle.  Or a fettle and tinker for that matter!
Quote from: Carolyn on January  3, 2021, 14:24Glad I did.  The cavities behind the liners (just in front of the door bottoms) were utterly jammed full of damp road grunge.  I was shocked to see how much came out when I took the compressed air to them.
Same thing in front of the rear wheels, below the side vents.
I have thought of deleting (obviously) the liners but they do keep spray in the wheel wells and are a useful aero measure.
Mr2paul
A while back i checked this and think I posted a warning too. To repeat, after blowing out the compost I was suprised to find as new metal. A blast with thinned down wax oil go into the nooks, but it will be a check to do on a yearly basis.
Learning is good. Failing to learn is not an option
Which one of you is Tinker and which is Fettle? :)
David seems more of a Fettle
scm2004red
Presumably you can't remove the liners without breaking most of the fixing clips?
MR2 Red Edition 2004
Porsche 924 1984
Quote from: scm2004red on January  3, 2021, 17:34Presumably you can't remove the liners without breaking most of the fixing clips?
I didn't break any - but I reckon that was a tad lucky.  Plus the liner was replaced about four years ago and I think I put new ones in at the time.
pauls0212
any idea of the size of clips,, think i may need some if and when i do this
red 2003 standard so far
Quote from: pauls0212 on January  3, 2021, 19:41any idea of the size of clips,, think i may need some if and when i do this
Same as the frunk surround plastics.
Mr2paul
If any use, rather than buy specific sized ones ( I already had 8mm but these too tight for frunk ) so I bought a selection of sizes n shapes to suit many jobs. We're only about £3/100 of eBay. I can post item if you get stuck but were easy to find.
