Changeable parts
Started by Mr2paul, March 26, 2021, 22:53
Mr2paul
Hi all, do fl headlights, bumpers fit a pre fl car ? Many thanks.
Learning is good. Failing to learn is not an option
Simple answer is yes, physically the only part not interchangeable between the two is the subframe due to additional bracing points on the FL.
It gets more complicated with the lights as there are changes needed with the wiring looms when swapping either way.
Mr2paul
Ok thanks. You confirmed my thoughts. It was a fl , but advertised as Pfl and I'm thinking the wriring is different. bUT he only had 1 but at £20 ish. If he had a pair I would of been in there.
