Fitting new rear brake caliper.
Started by CB 1971, March 31, 2021, 21:20
CB 1971
hi all, mot due soon and know its going fail on handbrake,had new cables last year noticed when trying to adjust drivers side not releasing as much as passengers side,cables releasing ok think its the caliper have never changed a caliper before thinking of buying self bleed kit and caliper and changing myself,is this a fairly easy job.
Yes.
Nothing special. Just a good old fashioned
 methodical approach.
No do not rush it.
SV-3
Quote from: CB 1971 on March 31, 2021, 21:20hi all, mot due soon and know its going fail on handbrake,had new cables last year noticed when trying to adjust drivers side not releasing as much as passengers side,cables releasing ok think its the caliper have never changed a caliper before thinking of buying self bleed kit and caliper and changing myself,is this a fairly easy job.
Only fit OEM ones - save yourself a lot of hassle (and the handbrake cables will work).
See this https://www.mr2roc.org/forum/index.php?topic=63117.msg837568#msg837568
Eclectic - not electric
Sony WX-920BT
"Hardtop Cognoscenti"
"Stock Cubed"
"AirCon Aficionado"
"Keeper of the Beeper"
gazza1286
Before getting too deep into the job make sure the handbrake cable pin on the caliper lever can be removed. The pin may be rusted solid and could need drilling or pressing out. Not easy and time consuming. The pins are dealer only parts.
Quote from: gazza1286 on April  1, 2021, 10:55Before getting too deep into the job make sure the handbrake cable pin on the caliper lever can be removed. The pin may be rusted solid and could need drilling or pressing out. Not easy and time consuming. The pins are dealer only parts.
A clevis pin?  Readily available on ebay, in stainless if wished.
