URGENT: Need to know depth of rear bins for Subwoofer instal
Started by Anonymous, May 4, 2005, 15:50
I am in the process of negotiating a 10" subwoofer deal (Diamond TDX).
I know they are 8" deep. I take it these would fit okay, boxed, into either rear bin on the MK3 MR2.
To be safe I would need to know that the 8" depth would go into the box equal to the circumference of the sub, i.e. 11-12" across
Many thanks
Stu
Stu,
if it helps to know i have a 10" Bazooka sub placed in the middle of the cubby hole doors that are bonded together and i have no worries at all in fitting it in, i'll find you a link to the specs on my sub for measurements
Stu
Thank you kindly mate, I would be interested in seeing those specs. I intend to run a single 10" from 1 side only, so the 10" won't sit in the middle of the two boxes.
Regards
Stu
where are you going to put the amp?
monobloc or bridged stereo?
I have an amp dilema
I have a Zapco CK9 XD which is 2 channel but gives 1 KW at 1 ohm from each channel or 2.5kw at 2 ohm bridged. It's not that big an amp but an amazing piece of engineering. This would be the sub amp.
I then need a 4 channel amp to run 2 ways active to the front, so I have 2 amps to locate.
Or I buy a 6 channel amp which does fronts and sub. The Memphis Belle is one that interests me.
Thanks mate I see the depth is only 5" the sub I am interested in is 8.9" deep, which really means that the bin has to be at least 10 or 11 inches deep.
Any chance you could stick a measuiring tape into one of the bins and tell me what the depth is please.
I would be grateful.
Stu
LeeUK
When you build the box make a spacer up, enough to let the sub fit. Once done smooth it all in with P38 and then admire your fine work!  Here's one I make earlier:
  s:D :D s:D
[size=100]JELBE[/size]
[/color]
You're becoming a mod expert Lee. Is that your garage or workplace  s:?: :?: s:?:
LeeUK
Workplace, which I've now taken over with MR2 parts!   s:lol: :lol: s:lol:
Keep an eye out for my next install, coming soon!   s:P :P s:P
[/color]
Quote from: "LeeUK"Workplace, which I've now taken over with MR2 parts!   s:lol: :lol: s:lol:
I have now purchased a Genesis Audiophile Subwoofer 10" which only needs just over 5 3/4 inch deep mounting, so no issue there.
Lee that's a fine piece of work. Which side will this box go into?
Would you be willing to send me the specs on this box as I honestly need all the help I can get.  s:wink: :wink: s:wink:
I though as much with the RS boxes etc
Quote from: "LeeUK"Keep an eye out for my next install, coming soon!   s:P :P s:P
Look forward to seeing and hearing it sometime matey  s:wink: :wink: s:wink:
LeeUK
The box in the picture goes behind the driver's seat, my new box will have the sub in the centre with 6x9's either side of it slightly inverted inwards!
[/color]
