Potential 2 with oil burning
Started by MrChris, July 16, 2021, 09:27
MrChris
Hi all,
I've got my eye on a 2 to view this weekend I hope. The owner has been fairly honest it seems and admitted that their car "burns a little oil but has always done this" over the last 2 or so years. It's a 2001 pre-facelift. Precats have been removed, what do you reckon? I really don't want to find myself having to rebuild the engine.
s12vea
Unfortunately you won't know until you have purchased. Depending on the mileage you do it may not be an immediate problem. But long term ownership might require a rebuild
Another one won't hurt  .....
Mine used to use half a litre over 3-400 miles, I laughingly called that "a bit of oil", until you can quantify it yourself you're basically in the same position no matter what you buy.
People run oil burning engines for years and years.
@Ardent can quote the offical toyota litre per mile listed in the owners manual. It's quite a lot.
Check every time you use it for the first month and then once a month if its within tolerance.
Reminds me probably time to check mine again.
Iain
A little oil burning is no big deal, most engines do it.
If however its putting blue smoke out the back, thats a sign to walk away.
jonbill
IME rate of oil burning rises with RPM. so one user who never goes over 3500 rpm will say 'just uses a little oil' and the next user who hoons it all the way home  will wonder why its knocking and has no oil when they get home.
You can live with it, but you have to figure out the rate it burns oil the way you drive it.
As @1979scotte says, the Toyota handbook quotes oil consumption, it devotes half a page of the handbook to the topic. Maybe  because they were aware that the drivers of such vehicles would be exploiting it's potential. Any way Oil consumption :
Max 1.0 L per 1000km (1.1 qt/ 600 miles , 0.9 Imp. qt /600 mies).
Oil consumption, once noticed, will not decrease, some years ago the " answer" was to use a heavier grade, ie Duckhams Q20-50 slowed the rate of loss but it was not a cure.
It depends where in this cycle of events the engine is, if you really don't want to be rebuilding an engine and intend driving hard and long then perhaps this one is not for you.
Quote from: jonbill on July 16, 2021, 10:24IME rate of oil burning rises with RPM. so one user who never goes over 3500 rpm will say 'just uses a little oil' and the next user who hoons it all the way home  will wonder why its knocking and has no oil when they get home.
This is a great point.
If you're an enthusiastic back road blaster compared to a boulevard cruiser.
Beaten to it. Post #6.
If it burns less than a litre per 621 miles. It's in spec. Raised eyebrow with monical emoji.
Like everyone above.
Need some numbers for perspective.
If the seller openly states it burns some.
How much are they putting in vs miles covered.
Following on from the revs comments above, that's my experience too. If you go to view it get the owner to take you for a drive on rural roads, - encourage him/her to drive 'enthusiastically'.  If they don't use 5-6k revs you can be pretty sure it'll burn quite a bit more if you drive it harder than they do.
One other tactic is to take someone with you & get them to look at the exhaust fumes.  I went to see a very tidy looking Electric green (FL) & did exactly that. Following it I could see some smoke. Then left the car ticking over for a minute & gave it big throttle blips. Lots of smoke.
ManInDandism
Quote from: Ardent on July 16, 2021, 10:53Beaten to it. Post #6.
It all relative. I've never previously owned a car that burnt oil at a rate of knots by design. Seller might simply be comparing it to another of his cars.
Black 2004 Roadster
If I owned a car that burned oil and was fine with adding oil I would tell myself it isn't that bad and make the best of it.
 If I was a potential buyer and the owner said the same thing I would immediately disqualify it as an unknown and at least part of the price reduction should reflect that the engine will require a rebuild in the near future. It doesn't mean the owner is hiding anything, he or she maybe ignorant about the condition but it certainly a car to walk away from unless the price is right. At the very least a compression test is warranted.
