Anyone recommend a supplier for a gearbox?
Started by WWC, July 23, 2021, 12:29
WWC
Hello everybody!
Drone/whine from the gearbox believed to be bearing.
Local garage need to send it away or me to source a replacement.
Found a couple of options on eBay.
Anyone actually recommend someone they used in the past?
It's a 2003 5 speed.
TIA
Will
Quote from: WWC on July 23, 2021, 12:29Hello everybody!
TIA
Will
What have they quoted for a refurbishment?
Buying a secondhand unit is always a risk you never know how it's been treated.
God knows if you can still get new ones from Toyota. Imagine they would be prohibitively expensive.
WWC
Thanks chap, looking link £300/400 from eBay for a recon box so pretty good really.
Also a guy apparently from here selling a box too (non-recon but cheaper).
Curious if anyone has actually used a supplier and can recommend?
Thanks again.
Will
TIA
Willis
Refurbishment of gearboxes, I suggest, is best done by a specialist, something your garage is alluding to.
PS
The problem with your supplying a refurb or unknown used box and your garage fitting it is that there is a shared responsibility. If it goes wrong what do you do?
I suggest try to find a gearbox specialist that will do the complete work and offer a warranty.
I have known this done on an auto box by a company in Birmingham.
PPS
For example a www search found:
https://www.reconditioned-gearbox.co.uk/?gclid=Cj0KCQjw0emHBhC1ARIsAL1QGNe3xTWvT05LUFreMzEP3bWswuwzuoSnh7hp_DkOqFZDhWxDr16-KJAaAkDBEALw_wcB
The Other Stu
I had my 2ZZ fitted at SJ Autosport in Brum (I noticed from another post you're not a million miles away).
I'm pretty sure Jam will give you a price to get it done (I have no idea who they use) and fit. I reused my 1ZZ gearbox on the 2zz.
I know this is going to sound obvious, but make sure you get the clutch done at the same time. It's a £250-300 job on its own!
WWC
Quote from: The Other Stu on July 23, 2021, 13:35I had my 2ZZ fitted at SJ Autosport in Brum (I noticed from another post you're not a million miles away).
Unfortunately I had the clutch done about 500 miles ago!
Will look up SJ Autosport now though, thanks for the steer.
Roj
J-Spec is a good quality MR2 and Celica breaker based in Ayrshire in Scotland. Andy is an ex-Toyota guy and knows his stuff - top bloke too. I bought my 2ZZ gearbox from him and it was in great order. https://www.j-spec.co.uk/
