10 clicks excessive?
Started by Ac1962, July 26, 2021, 16:29
Ac1962
is 10 clicks on the handbrake excessive or normal? how many is the recommended ideal?
Beachbum957
Factory Spec in the manual is 5-8 clicks
litr0m
Does yours also grab so bad. I did new calipers,new discs and new handbreak cables but the handbreak issssss soooo weak.
'04 JDM Subaru Legacy GT Wagon
'05 EDM Toyota MR2 W3 Red Edition
Mr2paul
Surely if it passes the MOT then the handbrake is fit for purpose as testers don't seem slack on this safety issue ?  Or I could be wrong
Learning is good. Failing to learn is not an option
paulj
Too many clicks will get you a "insufficient reserve travel" advisory on your MOT.  It is worth adjusting it back to the 5-8 specification.  There is a how to on the adjustment method, follow it fully and you will get a working handbrake.  You only need to have the car a short while before you can do it from memory, mine gets an adjustment twice a year!
Today
In the late 1980's
