S.O.S
Started by Anonymous, May 9, 2005, 16:48
Hi chaps,
              Done a search on the pre-cat faluire and oil consumption stuff, but I have a couple of questions.
I recently changed the oil I was using to fully synthetic Magnatec and then noticed that I didn't have the power I used to have, also the oil consumption is high, keeping an eye on it just now.  Is that the problem with Magnatec?
Put it in for a diagnostic test and had to have a new manifold and downpie fitted.  One side of the pre cats had gone in the manifold, bits seemed to have just dropped into the downpipe!!!  No white stuff in the exhaust though.
Just got it back and the lack of pull was still there.  Feels like a fuel blockage.
Is it the oil - or could the pre cat have done some damage to the engine?
Help  s:( :( s:(
What else can it be?  What else can I do?  Do I need to replace the engine?
so.simple
It's probably the main cat that is blocked with all the debris form the pre-cats. Have them swap it ASAP.
Carlos
Quote from: "carole"Put it in for a diagnostic test and had to have a new manifold and downpie fitted.
If they didn't replace the main CAT, chances are that it's toast, blocked and slowly killing your engine (well, ok, quickly killing it).
If they did replace the main CAT, chances are your engine is toast - the oil consumption is a bad, bad sign of major blowby in the cylinders due to bits of pre-cat being sucked back into the engine, scoring the cylinders and ruining your cylinder compression.
Oh, and Magnatec is horrible, horrible evil stuff, never ever use it again  s;) ;) s;)  Ever.. Please, think of the kittens..
 m http://www.mr2roc.org/phpBB2/viewtopic.php?t=1864 m
may be worth a read of this ref themagnatec.
for teh record magnatec is semi synth. I don't beleive they do a fully synth?
Okay I will come clean I cliped a wheel on the motorway - I couldn't swerve too much as there were 3 guys changing their tyres on the hard shoulder - and blewout my tyre  s:oops: :oops: s:oops:    It was dark and wet and I had slowed to around 30 mph - no other visable damage.
3 days later the lack of pull started - stopped driving it - 1week later, max, it was in the garage getting fixed!!!  So I guess I broke the cat.
Went out last night and done the spped limit plus a little extra   s:wink: :wink: s:wink:   - went like a bullet - but it felt almost as if it had a turbo that kicks in, it never used to feel like that.
It used to feel like sh*t aff a shovel- as they say up here - now it sometimes just feels like sh*t.
Does this make any difference to the diagnosis?
Jap GT300
Have you got a noisy engine?  Does the sound dramatically change at different rpm's?
The engine you described doesn't sound very healthy.
I am begining to think I do need a new engine  s:( :( s:(
Put new oil (thick stuff) in and still running the same.  Coming and going, not like it's struggling to get the speed, just that lack of pull - strange
The mechanic told me there was smoke coming out and he couldn't understand it - but I had just put redex in to clear the blockage a couple of days before - so we thought that was the the cause of the smoke.
This mechanic also told me that Toyota have replaced engines in 5 year old cars due to cat failure!!!  Has never had a Celica with a problem though.
I am putting it in again to get checked out at another garage.  I hope it's not the engine.
This is an expensive business.  Can I get this one reconditioned?  Is it cheaper to do that?
