Running Rich and idle problems
Started by M.Dub, September 30, 2021, 10:46
Is there any kind of a 'seal' for keeping out dirt in storage?  Something physically blocking them?
M.Dub
Iv had the same thoughts but it's hard to see. It dose look like somethings in there but not sure if it's suppose to b or not.
Perhaps contact MAG and see if they use anything to seal them?  If they do, and they've been exposed to full pressure fuel...
M.Dub
I already have contacted them but not holding my breath tbh.
I'm pretty sure they've had full pressure at them. I'm guessing that's bad?
M.Dub
Lol you mean I will never get them out?
M.Dub
Is there any way to add a video clip?
Iv tested all the new MAG injectors along side some old ones and hooked them up to a battery. I can hear the solenoids operate in all my old injectors however the MAG injectors do nothing at all.
Quote from: M.Dub on November  4, 2021, 15:52Is there any way to add a video clip?
Generally people upload clips to YouTube or upload it to a online drive and link it.
Unfortunately we can't afford enough storage to accommodate people's videoclips :(
Beachbum957
#107
A simple check if you have a multimeter is to check the resistance of the injector across the connector pins.  I checked a good set of green injectors and got 13.6 ohms on all of them.  The Toyota spec is 13.4 – 14.2 ohm at 20°C (68°F)
M.Dub
Funny enough I tried this out of curiosity only checked 1 of the MAGs it was 29ohm
Beachbum957
Quote from: M.Dub on November  4, 2021, 17:42Funny enough I tried this out of curiosity only checked 1 of the MAGs it was 29ohm
Sounds like they sent the wrong injectors.
Quote from: Beachbum957 on November  4, 2021, 18:28
That's what I was thinking.  They sent me the wrong pistons once.  They put it right and I ended up with two sets of pistons.
Very odd that they have the same part numbers.
Unless mine are wrong as well :)
M.Dub
Even if they were the wrong ones for the MR2 they should still open when connected directly to a 12v battery?
Iv messaged them so hopefully I'll get a refund or another set sent out.
Honestly tho, I'm sick to death of changing injectors I never want to do it again!!
Hopefully 4th set lucky
jonbill
Quote from: M.Dub on November  4, 2021, 20:28Even if they were the wrong ones for the MR2 they should still open when connected directly to a 12v battery?
Don't ever touch my car, please 😀
M.Dub
M.Dub
Just for the record It's all the parts fault
M.Dub
Iv managed to free 2 of them up by just persisting with the battery so they now open and close, not that I'm planning on using them id just thought I'd let you know.
jonbill
I suppose its possible they are coated inside with some anti corrosion goo or something and it needs to get washed off. perhaps soak them in petrol?
I think some plastic film has got shot into them.  Maybe just soak them in petrol over night?.
M.Dub
Had a response from MAG, they acknowledge there may have been a problem with the injectors and are sending out a new set.
Good service from them in the end 👍
M.Dub
I must admit I'm not convinced that installing these injectors will fix the issues I'm having, Iv got a feeling it's something more sinister.
If these don't fix it given Iv exhausted all the simple options what else could it be and how would I diagnose it?
If 2 cylinders keep misfiring all the time and the other 2 misfire rarely given all 4 have similar compression, new plugs,good coil packs, new injectors, Iv check the electrical connectors.
What could it be?
I'm mindful that the engine has previously undergone a rebuild and concerned its something internal?
jonbill
you could check the cam timing.
Have you checked the valve clearances?
M.Dub
I haven't done either of those, Iv never done anything like that and don't really have a clue how to do it.
Is it something I could do myself with some Googling? Are they difficult to do?
