Steering Boss Advice + Info Required
Started by Gibla, November 13, 2021, 09:36
Gibla
After reading an entry from @Alex Knight regarding Nardi Personal Steering Wheels :- who gave a very positive recommendation
I decided to give it a whirl on Facebook Marketplace/Flea Bay.
and obtained a very tired,dirty looking leather 330mm Nardi steering wheel claimed to have come off a HondaCivic Type R for ~ £80 along with an assortment of fitting boss's (it should have been a 350mm but hey ho)
After a bit of cleaning by me and some fettling by @MattPerformance the wheel was fitted + I liked it that much decided to try for 'others' to fit my other cars also.
So I was extremely chuffed to get a 350mm Suede Neo Grinta + similar syle in leather, for what I considered to be a bargain price (both new/fairly new) BUT both wheels came with bosses that have proven to be unsuitable for my '2'.
eBay bosses that supposedly fit, in fact, don't.
Help required ......can anyone provide a link that would solve this please.
*** Edited***
Reliably informed that this definitely fits
HKB boss kit(Product code OT-237)
2001 Dark Green MR-S (6R4)
rusty0273
I'd avoid the generic Ebay bosses. Apparently they're on Alibaba for only a few pounds so that tells you all you need to know. I have one of these below. It comes with everything you need. The indicator self cancelling does work but is a bit hit and miss - no biggy. Other than that, seems to be a quality piece of equipment.
BTW You don't specifically need the widely reported 3.3 Ohm resistor for the airbag. I think this comes with a 2 Ohm which works perfectly. Just make sure its is seated securely in the airbag connector before starting the car.
Otherwise you'll get a fault light which needs to be reset with a coder.
https://www.ebay.co.uk/itm/162491876848
Gibla
Quote from: rusty0273 on November 13, 2021, 11:01I'd avoid the generic Ebay bosses. Apparently they're on Alibaba for only a few pounds so that tells you all you need to know. I have one of these below. It comes with everything you need. The indicator self cancelling does work but is a bit hit and miss - no biggy. Other than that, seems to be a quality piece of equipment.
Cheers sir
HKB seems the way to go :-) , quite tricky to find any in the UK I have found, just ordered 2 from 'Driftshop' who are located in the US and France
Keep thinking about this myself.
My usual concern is, does it result in the  wheel being closer to the driver?
I don't mind it being the same. But don't want it closer.
I would like a slightly smaller wheel.
Gibla
To be fair the OEM Toyota steering wheel is really rather good, but it would be nicer still if the column allowed up/down and in/out adjustment.
But, having said that the Nardi Personal (no doubt other aftermarket wheels can replicate as well) fits beautifully into the hand and I'm sure once fitted will be a desirable upgrade if like their baby brother.
330mm is possibly too small a size to go down to though Jason, it makes reading any instruments nigh on impossible.
rusty0273
I've played around a bit with a few options on wheels. Here's my thoughts to consider on the practicalities.
I have the HKB boss and a 40mm 'dish' wheel - that's basically a flat wheel.
I found that it was too far away from me and after a few options now have a 30mm spacer - perfect for me at 6ft. It would be ideal to be able to try a few spacers as its difficult to judge until you buy one and bolt it on. When you put a spacer on, the stalks are further away which is not ideal but livable if you have long fingers!
I have a 325mm diameter wheel which is similar to an Elise and I think is perfect for the MR2. 350 would be OK but the original 370mm I think is just daft in this car - a parts bin option.
The problem with the smaller diameter wheel is dials visibility - the top of the dials are obscured. The spacer helps with this to a degree.
So, there is not really a perfect solution when you change from stock but for me the compromises are worth it for the improved position of the wheel, knee clearance, improved feel from a smaller wheel etc.
Bossworld
Momo boss comes with the correct resistor and keeps the steering wheel pretty much same distance as stock (unless you go deep dish). Should be about £80 and be readily available. Might have pics in my reader's ride thread. Auto cancels indicators and collapses in a crash
You'll need to either adapt the stock horn wire (you can remove the white plastic connector and just keep the single pin) or make your own though.
I ran a 300mm wheel and it stopped my hip pain from having to put my foot at strange angles.
Zxrob
Quote from: Ardent on November 13, 2021, 11:26Keep thinking about this myself.
Go for it
I never really like the standard wheel and found it "awkward" on a track day, I fitted a momo with HKB boss, like night and day imo, I went for the 350mm wheel rather than the 330m , only slightly smaller than standard but totally transformed the feel for me
Rob
Adventure before dementia 😁
rusty0273
Quote from: Bossworld on November 13, 2021, 20:19Momo boss comes with the correct resistor and keeps the steering wheel pretty much same distance as stock (unless you go deep dish). Should be about £80 and be readily available. Might have pics in my reader's ride thread. Auto cancels indicators and collapses in a crash
One advantage of the HKB boss is that it comes with an adapter for the horn connection which swaps in for the OEM one and requires no modification. Other than that I think the kits are pretty comparable. Momo one was around £10 cheaper when I was buying last year.
Quote from: Gibla on November 13, 2021, 09:36After reading an entry from @Alex Knight regarding Nardi Personal Steering Wheels :- who gave a very positive recommendation
I've had the 350mm Neo Grinta wheel and Momo boss fitted for quite a while now, and here's my feedback:
* The Momo boss seems to be very good quality and worth the price - no issues with self cancelling at all also.
* You can de-pin the original wiring from the clock spring and pop this straight onto the earth for the horn button. It's fiddly, but it can be done. Recommended if you don't have a soldering iron and/or crimping tools etc. I used a very small electrical screwdriver.
* The wheel does sit fractionally closer to you than the OEM wheel - I'd estimate about 10mm closer. The only thing I've found this impacts is the indicators and wipers are slightly more of a finger stretch now, but certainly not anything off-putting. You get used to it quickly. I also like a wheel that's closer to me, as I need to have the seat all the way back.
* For a daily driver, I'd recommend leather over suede, as the suede wheel absorbs dirt a lot more than leather. For the occasional weekend warrior and track car, I'd recommend suede as you get more grip with gloves on.
* The reduction in diameter from 370mm (stock) to 350mm (Personal) is perfect for me. It's that bit easier to catch slides with a smaller diameter as you can make inputs/corrections 5.5% quicker. Also give more knee room.
* Each to their own, but I'm absolutely not a fan of dished wheels at all. They belong on drift cars where you need to let go of the wheel during opposite lock corrections. A flat wheel is better for me.
For reference, this is the wire you need to de-pin and re-attach to the clock spring.
The reason being is that the white plug fouls the back of the Momo boss.
You essentially do away with the white plug. The spade end connects to the horn earth.
Bossworld
Quote from: Alex Knight on November 15, 2021, 13:40For reference, this is the wire you need to de-pin and re-attach to the clock spring.
Yep that's the one. Cost me a tenner for a second hand one when I put the car back to stock!
Quote from: rusty0273 on November 13, 2021, 11:01https://www.ebay.co.uk/itm/162491876848
Interesting that an HKB for a Mk2 fits a Mk3, because unless their listing is incorrect, a Momo boss doesn't.
The Momo number is a 7733 & I've previously seen it listed as only fitting 4 cars. The Yaris, Matrix, & a Hyundai, so there are rarely used ones for sale.
But in looking up ebay just now there is a listing for Momo & the SW20. ??????
Anyone looking to buy.....bargain 20% off.....  ebay 123806369537
Ratty
Quote from: rusty0273 on November 13, 2021, 15:20I've played around a bit with a few options on wheels. Here's my thoughts to consider on the practicalities.
Interesting info from you there.
I'm 6ft 3 inches so am looking at getting a smaller wheel (300-320mm with flat bottom)and require the wheel to be a lot closer than standard (around 100-120mm closer).
Are spacers enough to achieve this or will I need a deep dish wheel, or both do you think?
And do HKB supply the spacers?
rusty0273
300mm is really small - like a go kart wheel. 320-330mm more realistic I would think.
I've never tried a dished wheel but other comments on here suggest that they are best avoided. HKB do have spacers but not widely available in the UK as far as I can tell. You can get generic spacers up to 100mm or if you want the assurance of something branded then B-G do a range up to 120mm.
https://www.bg-racing.co.uk/vehicle-equipment/steering-wheel-spacers
Take care buying the wheel as I recall there used to be loads of cheap copies around badged up as Sparco, Nardo, Momo etc.
Ratty
Quote from: rusty0273 on October  6, 2025, 23:03300mm is really small - like a go kart wheel. 320-330mm more realistic I would think.
Thanks for that mate  ;D  most helpful.
I guess another option could be fitting an additional quick release as this would bring the wheel even closer and be a security bonus.
300mm.....yeah I do like a really small wheel.......must be all those years go-karting and gaming on a 280mm wheel lol.
I used to run a 300mm in an Impreza and loved it.
Quickly got used to reaching further for the stork controls and not seeing the dials.
Been sitting in the car with a tape measure on the stock wheel trying to imagine 300 & 320 mm and I think my legs need it to be 300mm to get proper clearance for pressing the brake.
Also there's several you tube videos with them fitting 300mm in the roadster and I do like the look of them at that size.
My biggest concerns is MOT time and if they let it pass.
Would be a right balls ache to have to swap back to stock wheel every MOT time.
Also not looking forward to the electric side of it with the horn and the air bag warning light.
rusty0273
It will fail MOT without the airbag wheel fitted (some 'friendly' testers who do modified cars might let it pass but it shouldn't).
The HKB hub option provides all you need with a resistor for the airbag (use the larger of the two pin options) and a replacement connector for the horn - no need for any manual wiring. All reversible.
In my original post I mentioned the auto cancellation for indicators being hit and miss but it turned out I hadn't located the clock spring correctly at first so that now works as expected.
In terms of MOT, I disconnect the horn and unbolt the hub/wheel assembly. Bolt on the original wheel and connect the horn but not the airbag. So, no messing about with the airbag resistor. Visually, its as original, no lights and obvs they don't test the air bag functionality. Not a big job once you understand how it fits together.
In my view for the taller gent (or lady) a smaller wheel & spacer transforms the driving. I couldn't live with the original wheel - driving to the MOT centre once a year is bad enough.
One tip - do not start the car unless the airbag resistor is well connected/positioned. The airbag warning light needs an 'advanced' OBD2 device with safety systems access, to reset it. A pain to sort out if you don't have one.
Ratty
Thankyou mate,that's really helpful.
Been thinking about it all day and might have come up with another solution involving lowering the seat.
Would much prefer a smaller wheel ,but not sure I can be done with the MOT hassle.
You explained it well though so it's still thought in progress.
Think I'll start a new thread on the subject of improving leg room.
steveash
I've wondered about this myself. I found this but never actually bought one: https://spacershop.com/product/steering-wheel-spacer-for-toyota-mr2/
