Plastic Nappy
Started by Two's Company, May 14, 2005, 15:07
Two's Company
Does anyone know what size the bolts are that hold on the rear nappy?  One of mine has gone missing.
I only remember it needs a 10mm key  s8) 8) s8)
Both bolts are same, so just take the other off and measure it or take it with you to nearest "bolt store".
Quote from: "Two's Company"Does anyone know what size the bolts are that hold on the rear nappy?  One of mine has gone missing.
If you find out can you let me know - one of mine has gone AWOL as well.   s:roll: :roll: s:roll:
Thanks.
Just went to check it, M6x1.0, about 15mm long.
Quote from: "Tem"Just went to check it, M6x1.0, about 15mm long.
Cheers Tem.   s:) :) s:)
Quote from: "Tem"Both bolts are same
Both?  Insignificant information but mine has three...
Just taken nappy off for Plus Gassing pre cat-gut.
My 2004 has 2 self tappers at rear of nappy, 2 bolts at front   s:? :? s:?
Quote from: "Emmanuel"
Mine has two bolts, three screws and one plastic clip. The three that hold them to the rear bumper do have a 10mm end and might look like bolts before you take them off, but they are screws.
Two's Company
I finally found the time/weather to look at this at the weekend;
At the last service Mr T told me there was a bolt missing which they replaced.  When I got home I noticed the plastics 'hanging down' at one side, had a quick look and they had put a cable tie around the two 'nappies' which I assumed was because they didn't have the right sized bolt lying around.  So I got under the car on Saturday and undid the other side so I could go and buy some replacement at B &Q and the bolt snapped! Looked at the other side and that's what Mr T had done as well hence the cable tie!
I've now taken the rear plastic off and left it in the garage.   s:wink: :wink: s:wink:
Quote from: "Two's Company"When I got home I noticed the plastics 'hanging down' at one side, had a quick look and they had put a cable tie around the two 'nappies' which I assumed was because they didn't have the right sized bolt lying around.
Damn it, why do we tolerate sh*t service like this?  I know it's a simple thing but f*ng hell...
A cable tie instead of a screw.  Damn it.
Sorry, I just had a few too many arguments with Culvers Macclesfield; a totally useless garage that gives me the impression that would happily do something like that - or worse.  I hope the garage in Guildford is better...
obviously thought no-one would ever look
DOH! go get the buggers
