Rear shock replacement
Started by Newbie57, January 27, 2022, 15:57
Newbie57
Did the fronts last year. Relatively straightforward.
How do you get the drop links off the rears?
I think most people have a new set on standby when they do this job as they get very rusty and often have to be cut off. There is an allen key needed to stop the centre from turning while you try to undo the nut but even after a couple of years on the car they will probably need replacing so get a set off ebay before you start and have the angle grinder to hand!
