Problems fitting ebay power steering pipes
Started by blumr2, March 29, 2022, 13:42
blumr2
Has anyone tried fitting replacement power steering pipes from "atozofcarparts" on ebay?  They look like a good quality set but I just can't get them to line up and fit correctly.  Looks like the high pressure hose is too short.  The seller says he's sold over 170 of them, so must be something I'm doing wrong but can't for the life of me see what!  Any suggestions very welcome.
Pics show the old rack, another one I am reconditioning with the new pipe screwed on (shows how far off the support collar is from the mounting hole on the rack), and finally the new pipe held over the old rack to compare the pipe lengths.
@blumr2
Are these new pipe supplied as a direct replacement for the OE pipes?
If so, to my eyes, they are a different shape to the OE.
Have you sent your photos to the supplier or just advised that they don't fit?
That would then be my starting point.
blumr2
Thanks, yes supposed to be a direct replacement and yes they are a slightly different shape to OE. I've sent the vendor pics and they can't help as they just sell them and don't install them.  Although they are happy to take them back, they say they have sold dozens with no complaints. I was wondering if someone here has successfully used them in case I'm being thick and there is a hidden knack to this.
Link to their listing:
https://www.ebay.co.uk/itm/170627605717?hash=item27ba32a4d5:g:PqAAAOSwbVJfMHG9
fawtytoo
Personally, I'm wondering why all his listings are private. What's he hiding?
And he does have 1 neutral feedback stating it didn't exactly match the OEM part (incorrect mounting).
If they've sold dozens like the picture in their ad then they won't have had complaints but the one in your pictures is bent to a different profile.
The return curve looks too wide and has taken length out of the pipe, could maybe reprofile it to make it fit if you're desperate but otherwise it's going back.
Quote from: Call the midlife! on March 29, 2022, 17:36If they've sold dozens like the picture in their ad then they won't have had complaints but the one in your pictures is bent to a different profile.
We were out for the evening so didn't follow up, but I do agree with your conclusion other than I wouldn't try to reprofile the tubing, too easy to crack tubing. I would send it back as not as advertised , unfit for purpose in which case the supplier should pay for the return.
blumr2
Thanks all, will try another one from another ebay vendor and see if have better luck. Building a track car, so steering is kind of important  ;D
Bossworld
On my old car, the pattern pipes I bought had a metal clamp/clip between two of them. With that in place, there was no way on earth it was ever going to fit. I removed it, and it was OK.
I'm struggling to remember which one, and compare it to your pictures, but it looked similar to the silver piece of metal sat on your steering rack.
Obviously if it's miles off, just send them back as others have said, but just in case it's any help for the replacements.
Quote from: blumr2 on March 30, 2022, 11:25Thanks all, will try another one from another ebay vendor and see if have better luck. Building a track car, so steering is kind of important  ;D
Steering is kind of important on most cars, better luck with your new supplier.
These are the ones I bought;
ebay link
TheTigerUK
Apart from possible fitments issues are there any other problems associated with fitting a new set of pipes ? mine were really rusty when I looked so it would be nice to have some new ones.
Not sure if they are available with a chromium finish John😉
More seriously, the steering Universal Joint also looks unloved. I suggest checking for any slack, grip top end and twist too and fro, shouldn't be any movement.
If OK clean it up and grease it up.
If not OK I believe TCB do a good deal on a replacement.
If slightly OCD there was/ is a bellows shroud available from a Member on here, https://www.mr2roc.org/forum/index.php?topic=69674.0 but with your workshop I'm sure you could make your own.
 While speaking of TCB he could be worth a try with pricing for replacement pipes.
If you decide to replace the pipes I suggest you also clean the pump motor and drain/ replace the PS fluid. Ravenol is the fluid, as used by @Carolyn.
No, sorry, there is no cure for what you have developed in your ownership!
TheTigerUK
Quote from: Joesson on April  1, 2022, 11:26Not sure if they are available with a chromium finish John😉
Chrome would be nice Tony :) but just new would be even better, the area did look better after a clean, derust etc.
blumr2
Quote from: Joesson on March 30, 2022, 16:40Steering is kind of important on most cars, better luck with your new supplier.
Indeed, my poor attempt at a joke..
So another set of pipes arrived at the weekend, this time from here:
https://www.ebay.co.uk/itm/154612233975
The fittings were not quite as good quality, but it fitted perfectly so now up and running.  Quite a simple job, if you can get the old pipes off. The other pipes now going back..
Thanks all for the feedback.
David
Looking good! Hope you remembered to tighten that wishbone screw up?🤓
That looks much better @blumr2 , I do hope that the original supplier puts his hands up, admits the obvious fault and refunds the return costs.
TheTigerUK
Quote from: blumr2 on April  5, 2022, 00:15Quite a simple job, if you can get the old pipes off.
David
Looks good, do you have to bleed the PS system or anything or do you just top up the PS fluid ? thanks
Quote from: TheTigerUK on April  5, 2022, 10:49Looks good, do you have to bleed the PS system or anything or do you just top up the PS fluid ? thanks
These are the links I followed when I cleaned the pump and changed the EPS fluid to Ravenol:
EPS fluid change
https://youtu.be/ElmEb6PKZ50
EPS pump clean
https://www.spyderchat.com/threads/ps-light-power-steering-problems-try-this.50843/page-2
Bossworld
Quote from: Joesson on April  5, 2022, 10:58These are the links I followed when I cleaned the pump and changed the EPS fluid to Ravenol:
EPS fluid change
EPS pump clean
Nice to see someone else go for the 300mm wheel (by the looks of it).
blumr2
Yes, but very easy - just turn the wheel lock to lock with engine running and top up the reservoir as needed.
TheTigerUK
Quote from: blumr2 on April  5, 2022, 21:08Yes, but very easy - just turn the wheel lock to lock with engine running and top up the reservoir as needed.
