Rear control arm ball joint spinning
Started by MrChris, April 6, 2022, 08:24
MrChris
Attached my rear control arms (at least I think that's what they are  :)) ) and I can't put the nuts on as the thread which comes from the ball joint part just keeps spinning. Couple of questions:
1. Are they knackered or is there a knack to fixing them on?
2. Is it possible to put more grease in to the ball joint area?
Quote from: MrChris on April  6, 2022, 08:24Attached my rear control arms (at least I think that's what they are  :)) ) and I can't put the nuts on as the thread which comes from the ball joint part just keeps spinning. Couple of questions:
Is it the fresher ones I put in the car or the originals?
I've never fitted the black ones so can't confirm but could try the original to see if it catches. There's nothing in the manual about a knack other than that it says to use a new nut. I've never had those arms off at the hub, only at the subframe.
Torque should be 49nm after stabilising suspension. That's the rule anyway, always lower the car and let it settle and then tighten the bolts to torque.
MrChris
It's the one's you included, when I took off the originals I managed to squeeze out the grease hence my question about putting grease back in! Maybe I'll get a new nut but as soon as I start to tighten, the whole thing spins.
J88TEO
If the nut is just spinning then you might have stripped the tread.
If the ball joint itself is spinning then you need to apply a bit of pressure from the back and tighten the nut.
MrChris
Quote from: J88TEO on April  6, 2022, 08:57If the nut is just spinning then you might have stripped the tread.
Yep it's the ball joint itself. I will try this approach thanks.
mr2garageswindon
I usually put a big pair of pipe grips behind the ball joint to one side of the nut (Not best angle) and squeeze together while doing the nut up.
Are you using an impact wrench? If not then try one, sometimes the speed/inertia of the wrench beats the friction from the threads.
Just don't ugga dugga the life out of it.
Quote from: Call the midlife! on April  6, 2022, 09:31Are you using an impact wrench? If not then try one, sometimes the speed/inertia of the wrench beats the friction from the threads.
Absolutely 💯  don't dugga the life out of it.
It also really helps to make sure both the taper and the socket are absolutely clean and grease free.  I use brake cleaner on taper joints.
mr2garageswindon
If all else fails then a dab of valve grinding paste on the shank to give added friction to stop it spinning... Shhhh don't tell everyone its a trade secret...
