Main Menu
Alloy Wheels
Started by alancdavis, April 7, 2022, 13:05
alancdavis
Can I ask what wheels from other cars have the same PCD as the MR2 and will fit
Red Calipers with DBA Cross Drilled and Grooved Discs,,,,2005 Red and Black Leather Custom Seats,,,,,TSW,17ins Wheels,,,,,2003 colour coded side vents and rear bumoer inserts,,,,Custom rear bumper skirt,,,TTE Twin Rear Pipes,,,,,,TTE Front Bumper,,,,,Red and Black Steering Wheel,,,,,Blitz Induction Kit,,,,,TTE Style Bar,,,,,Goodridge Stainless Braided Hoses,,,,,,,,,Front and Rear Strut Braces,,,,,,Rear spoiler
Bossworld
4x100 PCD is extremely common. What you need to look out for is the offset/ET, and that if you're getting them second hand with tyres included, it's likely you'll be back to a square setup rather than the factory stagger.
Quite a few Mazda MX-5 wheels will fit the 2.
alancdavis
S for the whhels to stick out from the cat I need a + offset and to stick more inwords a - offsett
Ensure that the center bore is at least 54.1mm
Bigger and you can use spigot rings but smaller and it no fit too good
Quote from: shnazzle on April  8, 2022, 21:08Ensure that the center bore is at least 54.1mm
Auto correct strikes again.
TheTigerUK
Quote from: Ardent on April  8, 2022, 22:06Auto correct strikes again.
I have advised him, does anyone proof read ?
Oh no!! Thanks heaps @TheTigerUK for the warning.
I was watching TV at the time so wasn't paying attention. I'd like to think my phone would have auto-corrected that for me to be what I intended it to be,which would have saved some embarrassment.
Apologies to those that read that. Obviously not intended.
alancdavis
So what off set is the best ???
Quote from: alancdavis on April  9, 2022, 01:14So what off set is the best ???
That entirely depends on what you're doing and your preference. But unless you're tracking it I'd say stock et45 is best.
If you're lowered, anything over et38 is going to cause rubbing in the rear wheel arches.
Just to correct your earlier post, the lower the ET, the MORE it sticks out. So et35 sticks out 10mm more than et45.
As said above, it depends on your tyre width and suspension set up.
I found ET35 too much with the car lowered, rolled arches and 225 rear tyres. The front was a bit more forgiving. ET38 may have been ok with that set up but a bit of a gamble unless you can find some 2nd hand wheels and try them first, thats probably very unlikely!
Et38 definitely works on a lowered car without issues. Tiniest bit of rubbing at full compression but only if you listen very closely. And that was with 225 width tyres so stock 215 won't run at all even lowered.
This setup worked.
6.5j et38 + AD08R 195/50/15 (Front)
7j et38 + AD08R 225/45/16 (Rear)
Quote from: shnazzle on April  9, 2022, 08:14Et38 definitely works on a lowered car without issues. Tiniest bit of rubbing at full compression but only if you listen very closely. And that was with 225 width tyres so stock 215 won't run at all even lowered.
Hmm.
ET38 with 195 front and 205 rear on the not all that lower TRD Sportivo rubs fron and rear if I push the AD08Rs to the limit.
Willtheyfit is a great tool but be aware that it bases the distance in and out on the rim entirely. Also it does not allow for half sizes. Thus good for circumferance/hight, not for width.
Today I have cleaning and shining the OEM PFL rims on the agenda. Would lóve them on the Kei Wagon :-)
Quote from: Petrus on April  9, 2022, 10:01Hmm.
Now that you mention it, you're right with 195s front it does rub a tiny tiny bit.
Just stay stock!!
Et45 6.5 front, 7.0 rear. Done.
It's best. It really is.
Even if you get lower offset wheels to fit you may encounter the responsive feel diminished. Some people are in tune with it and others don't care but it kind of robs some of the go kart character this car is known for.
Staying with factory offsets is the best way unless you are willing to compromise a little.
Stock wheels and skinny tyres = grin factor × ♾
PSA: I have 195/50/15 F and 205/50/15 rear, on a 7J ET35 wheel all round, and my car is lowered on Tein SuperStreet coilovers. Never had a wheel fitment/rubbing issue ever.
alancdavis
Thanks for all the advice to date Gents
alancdavis
found thisYou cannot view this attachment.
alancdavis
S it is correct that a negative offset will stick out the most
rusty0273
alancdavis
S U B J E C T I V E
Do what you prefer, not what the internet tells you to do.
