Amayama Handbrake Cables
Started by JohnGee, April 8, 2022, 09:14
JohnGee
Got my handbrake cables this morning from Amayama, arrived via UPS wrapped and in a box with packaging that would have seen safe delivery of fresh eggs from Japan.
Order placed on 29 March, order confirmed 30 March, received 8 April. I'm impressed.
Future job (before next MoT).
John
2006 Roadster, manual, leather, in Sable
Silver55
Good luck with the install
How much delivered inc taxes and customs fee? Also PFL or FL cables?
JohnGee
Quote from: JB21 on April 11, 2022, 10:14How much delivered inc taxes and customs fee? Also PFL or FL cables?
Facelift cables.
£35 each cable, £56 delivery (ouch!), total £126 paid to Amayama. No customs, VAT or other demands (to date) 🤞
John
JohnGee
Quote from: Silver55 on April 11, 2022, 09:41Good luck with the install
Thanks, I've read the advice on here and I might post a couple of questions before I start.
John
@JohnGee
This will cover most of it.
You do not need to "fully" remove the tank, just lower enough.  But other wise this pretty much covers it.
Quote from: JohnGee on April 11, 2022, 12:48Facelift cables.
Very surprised UPS released this to yourself without requesting 20% VAT and a duty rate %. It may come in the future...
Did you price these up from Toyota UK?
JohnGee
Quote from: JB21 on April 12, 2022, 09:27Very surprised UPS released this to yourself without requesting 20% VAT and a duty rate %. It may come in the future...
Future demand - possible, hence the crossed fingers in my earlier post.
Yup, £250 the pair!
John
JohnGee
Quote from: Ardent on April 11, 2022, 22:21@JohnGee
Thanks, I've looked at this previously, but there's a heck of a lot going on, the removal of the rear cubby liners so that you can disconnect the fuel filter and a couple of lines from what is identified as the evap unit, plus a good number of disconnects and freeing of lines and braces under the car. But in the video, the chap chose to drop the tank completely, so presumably that's why he had to do all the disconnects.
I'm hoping to do it with a nominal tank drop (famous last words) 🙏
John
Quote from: JohnGee on April 12, 2022, 11:43Thanks, I've looked at this previously, but there's a heck of a lot going on, the removal of the rear cubby liners so that you can disconnect the fuel filter and a couple of lines from what is identified as the evap unit, plus a good number of disconnects and freeing of lines and braces under the car. But in the video, the chap chose to drop the tank completely, so presumably that's why he had to do all the disconnects.
Yes  - loosen the bolts that hold the tank in but don't quite take them out.  That much drop will give you enough room.  The cubby hole liners do have to come out, though.
JohnGee
Quote from: Carolyn on April 12, 2022, 12:11Yes  - loosen the bolts that hold the tank in but don't quite take them out.  That much drop will give you enough room.  The cubby hole liners do have to come out, though.
Loosen the bolts - 👍
Cubby liners out - OK, thanks, but presumably having taken them out there are then a number of disconnects or similar to do. Presumably just taking the liners out doesn't somehow improve tank manoeuvrability?
John
Iain
Did mine without disconnecting any of the fuel filter lines or moving cubby liners.  Took bolts completely out and kept it steady on a trolley jack just enough to not stress the wires. Fiddly, but do-able with some patients.
Also, have a close to empty tank, helps alot.
TheTigerUK
Quote from: Iain on April 12, 2022, 13:04Did mine without disconnecting any of the fuel filter lines or moving cubby liners.  Took bolts completely out and kept it steady on a trolley jack just enough to not stress the wires. Fiddly, but do-able with some patients.
Would patients be healthy enough to help ? sorry I will get my coat, couldent resist :)
Chilli Girl
Yes I should get it John.  No chit chatting on this post please ;)  😂
Silver55
exactly how I did mine a few weeks ago.
JohnGee
Quote from: Silver55 on April 15, 2022, 08:07exactly how I did mine a few weeks ago.
@Carolyn advises that the cubby liners have to come out, see above, did you have to do that? I don't really see what that adds to the drop, though I've never dropped the tank so it's probably down to my lack of understanding.
John
Quote from: JohnGee on April 15, 2022, 08:36@Carolyn advises that the cubby liners have to come out, see above, did you have to do that? I don't really see what that adds to the drop, though I've never dropped the tank so it's probably down to my lack of understanding.
It's a long time since I did mine -so I may well be wrong. Taking them out is not a big job though.
Silver55
I didn't remove cubbies or disconnect anything. I had in mind that I might have to if it got tight, but I managed enough wriggle room for skinny arms without anything getting tight or snagging.  It might be different with aircon though? - I've read that gets in the way.
JohnGee
Quote from: Carolyn on April 15, 2022, 08:57It's a long time since I did mine -so I may well be wrong. Taking them out is not a big job though.
John
JohnGee
Quote from: Silver55 on April 15, 2022, 09:16I didn't remove cubbies or disconnect anything. I had in mind that I might have to if it got tight, but I managed enough wriggle room for skinny arms without anything getting tight or snagging.  It might be different with aircon though? - I've read that gets in the way.
Thanks, I've no air coin either, so less clashes. When I do it, I'll just try dropping the tank on the bolts, but will be ready to remove cubby liners and other bits n pieces just in case.
John
